Boot Brace Rivits?
Keoke
Boot Brace Rivits?
/ubbthreads/images/graemlins/savewave.gif
Hi All, What is the size of the rivits used to attach the rear shrowd to the boot brace?.--Keoke
Keoke
Keoke
Re: Boot Brace Rivits?
HI Skip, thanks for the reply. How long should they be I have selected 100 Deg Flat Heads.---Keoke
GregW
Platinum
Hi Keoke,
Here’s what I used. They worked pretty well.
Keoke
Keoke
Hi Greg I was wondering where all da rest of the riviters were that is cool.What do you call them, where can I get them and how do you make them stick together.---Keoke- /ubbthreads/images/graemlins/grin.gif
GregW
Platinum
Hi Keoke,
They’re called tubular rivets. I think they can be had at:
Culver City Hardware
5429 Sepulveda Blvd
310 398 1251
That’s where I bought those copper pop rivets I mentioned a while ago. One piece per hole. The hollow end gets expanded. I made a riveter out of a C-clamp with a center punch welded to it. See this thread for a photo. I balked at the price of a real squeezer for the small job I needed it for. The one downside is a little crease that gets made in the head of the rivet. I can work on fixing the tool. I just did a light sanding of the rivet head once they were installed. You can borrow mine if you want. I’ll be going to Downey on Friday passing your neck of the woods.
Keoke
Keoke
OK Greg, I Know that place I will check there tomorrow.The shop that is loaning me space is closed until tuesday so I will not be doing anything until then.I may bite the bullet and buy the anvil for the rivits and use a "C" clamp too.I sincerly appreciate your offer and I may just end up borowing it in the end.Thanks Much---Keoke
Skip & Lynne
Hi Keoke if you use the solid rivets the worked or driven end should be 1&1/2 times the origional rivet shank diameter. Skip
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
S Boot Liner - BJ8 Austin Healey 19
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
CJD TR2/3/3A Boot Seal Pics Triumph 17
J BJ8 boot rubber strip Austin Healey 9
CJD TR2/3/3A TR2 Boot Strip Triumph 22
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Rut TR4/4A Boot and bonnet bodywork. Triumph 4
D boot rubber ??? Austin Healey 2
Rut TR4/4A Parts in boot Triumph 11
SASSAMON TR2/3/3A TR3 Boot Construction Info Wanted Triumph 2
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
Rut Top frame and boot panels Spridgets 2
