Converting Rear Reflector to working lamp
Dave Russell
Yoda - R.I.P
AUSMHLY
It's great reading posts and solutions such as this one. I love making safety impovements, that are not obvious, or too obvious. I too will be making this one. Thanks Jerry for the question, Dave for the link and Laurie for your article. Cheers /ubbthreads/images/graemlins/cheers.gif Roger
Keoke
Well thats real cute. However, IMOP the safest improvement you can make is to install a high visibility Tail/Stop light.---Fwiw---Keoke
Michael Oritt
[ QUOTE ]
Has anyone been able to convert rear reflectors to lamps?
[/ QUOTE ]
I have that on my 100--since I have a high third brake light I have the rear reflectors rigged as turn signals. They use the conical shaped lens which I think was off 100-6's.
Cottontop
Replacing Rear Reflector to working lamp
Here's mine.
I replaced the reflectors (1 was lost anyway), with an aftermarket truck & trailer clearance lamp ($1.99 ea.)
The upper light comes on with brakes and turn sig. only. Lower light works normally
Please Email me if you want further details.
Tim
Keoke
[ QUOTE ]
Have done that.
RJA
[/ QUOTE ]
RJA, does it work as both a Tail and Stop light??---Keoke
R
RJA
Keoka,
I am going to make it work with the tail and stop lights.
I have not yet installed the lamps. I have a 3rd brake light mounted on the trunk lid already.
Jerry
Keoke
Yes RJA, that was my interpretation of your earlier reply.However, I was asking if your Third Brake light also functions as a tail light.?? ---Keoke
Keoke
OK RJA, if your third brake light contains leds it can be very easily modified to perform both functions.---Keoke- /ubbthreads/images/graemlins/yesnod.gif
Ed_K
Bob,
When you get ready to buy new tires and have them properly installed, balanced , and trued, drive down to Hendrix Wire Wheel. They do 1st class work and I really like their Gillet tires. It was more than worth the drive and time.
/ubbthreads/images/graemlins/thumbsup.gif Ed
Ed_K
Re: Replacing Rear Reflector to working lamp
Excuse my ignorance of the older models. Are the reflectors in my 65 BJ8 the same size as Cottontop's and the ones shown in the link that Dave has posted for the addition of an LED to an existing reflector ?
I think that both are excellent safety modifications.
AUSMHLY
I found this on the net, https://www.bighealey.ltd.uk/
If your interested in replacing the refectors with small orange tailights, that look like smaller versions on the phase II cars, check it out.
I am going to modify my refectors, as mentioned in the beginning of this post. Putting the bulb behind the reflector, so it appears stock, untill the brake or turn signal is use.
But, if someone wants an orange tailight, where the reflector was, this just may be the ticket. Roger
T converting rear reflector to brake light Austin Healey 16
pan Rear axle- Converting to wire wheels Austin Healey 6
nevets interesting article about converting classic cars to electric power Austin Healey 7
D TR4/4A two questions- converting generator to alternator and breather cap query Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
K TR2/3/3A Converting to Negative Ground....... Triumph 12
K TR2/3/3A Converting to Positive Ground....... Triumph 1
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
drooartz MGB-GT Decided - converting to bolt-on wheels MG 3
T Converting a BJ8 into a racer Austin Healey 8
drambuie Converting a smiths clock to positive ground Austin Healey 12
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
Mark_Barton TR4/4A Converting to ballasted ignition? '62 TR4 Triumph 8
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
T converting disc wheel BN4 to disc brakes Austin Healey 12
T Stag Converting a Stag from auto to a 5 speed Triumph 3
B Converting to Neg ground Spridgets 5
AH67 Converting wheels on a 62 BT7 Austin Healey 3
C Converting to DOT 5 Triumph 6
T TR2/3/3A Converting TR3A to Wire Wheels - Torque Specs? Triumph 3
middie Converting from US to UK radiator in a late 1500 Spridgets 10
L Converting a Midget MG 8
MadRiver Converting to a Surrey Top Triumph 5
QuickSilver Technical: Converting From Wire Wheel To Standard MG 6
Z Converting Power/Torque to Metric Units Austin Healey 1
Newkie Converting Positive ground to Negative ground MG 4
QuickSilver Converting Rubber To Chrome MG 1
M Converting to RHD Austin Healey 8
amcboy Post-War Other Difficulty in converting Volvo 1800 J-type O/D? Triumph 6
spit71 Spitfire Converting track width on MKIV Spit? Triumph 5
S Converting to Negative Earth Spridgets 15
Camshaft Converting BACK to lever shocks MG 5
drooartz Feeling stupid -- converting tachs Spridgets 11
drooartz Converting to RHD Spridgets 10
soren_ak converting a BN 1 100-4 ´55 from LHD to RHD Austin Healey 1
kyreb1862 Converting to SU's MG 9
T Converting a 3000 back from a V8 conversion Austin Healey 7
S converting from wire wheels to studs Spridgets 4
A TR4/4A Converting TR4 gear box to O/D Triumph 4
N MGB-GT Converting A 77 B GT from RHD to LHD MG 7
A Converting a non-o.d. tranny to a J-type Triumph 12
TR4 Converting from Stromberg to Weber Carbs? Triumph 23
W Converting to wire wheels MG 1
L Rust Inhibiting or Converting Paints Austin Healey 1
W Converting from American to British Bumpers? Jaguar 1
S Converting from a knock-off to a 5-bolt hub. Jaguar 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
