healeynutt
I recently acquired a 65 BJ8 with 65K miles on it. It has relatively low oil pressure. Start up around 50 #, engine hot idle 15 #, 2500 + rpms about 25#. Relief spring and valve are new and the guage is correct. The rocker arm assembly is in good shape. I suspect that the rod and main bearings are worn. My Haynes manual suggests for long engine life to change the big end bearings at 30K intervals and mains at 50K. It goes on to say that this should insure a long crankshaft life.
Anyway, my newbie question. Can the mains and rod bearings be changed without pulling the engine?
Obviously, I would mic the crank to insure its specs. I suspect that the rod bearings can be changed, but am unsure about the mains and the thrust washers. Actually I have never look inside a Healey engine. By the way compression tested around 150 on all cylinders.
Thanks.
Thanks.
