Rocker Cover Data Plate
HealeyKissed
For a 65 BJ8, I am looking for the aluminum & black lettered rocker cover ID plate (not the decal) stating "... .012 COLD." I've contacted the usual suspects and then some, without success. Any suggestions welcomed.
H
HealeyKissed
Reid,
The plate is listed on AH Spares website and in their catalog, but they do not have it and they can't get any more plates because their supplier is out of business. I've called the "usual suspects" in the UK. Reckon I'm looking for something really unusual.
Editor_Reid
Platinum
Without checking their website, have you tried British Car Specialists in Stockton, California? Great folks, REAL Healey people, and they have a small catalog of rare parts, and this is the kind of thing that might well be in it.
Healey Nut
Have you tried these guys
http://www.clarkespares.com/
failing that the rocker covers come up on flea bay regularly, I think I may even have a spare floating around in my shop .I may even have the plate as well as I replaced them on one of my BJ8s .
will look tomorrow.
Editor_Reid
Platinum
Also try Tom's Import Toys; real Healey people as well (Tom has owned over 70 Healeys): https://tomsimport.com/
Momentary off-topic diversion: I thought Tom claimed that he has had well over 400 Healeys pass through his hands, and claims he has sold more Healeys than anyone else, anywhere, anytime, anyway. Not sure how many of them were really personally owned, and not just merchandise to flip :greedy_dollars:
RT
Bob_Spidell
I confirmed the guy with the barn find and '300 Healeys' mentioned in the latest Moss blurb was Tom. His wife Skip, who works in the biz and is a delightful lady, said that was 'a tad exaggerated.'
dougie
True and that was my open trailer in the barn in the Moss article.....
H
HealeyKissed
I've contacted all the businesses suggested in this thread, except Clarkespares. They will be contacted next. This plate is a very elusive item. BSC has a few used ones, but I'm refreshing my engine bay after 30+ years and would prefer new (if possible).
Healey Nut
will look tomorrow.
I didn’t have any luck in my spares pile . Must have either sold them or junked them .
Hamish Racing General TR Rocker cover identification please. Triumph 2
Twit TR4/4A 1.5 in outside diameter rocker cover pipe Triumph 3
Joe_Healey 100 Chrome Rocker cover and air cleaner option Austin Healey 0
P Rocker Cover Vent Spridgets 22
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
M TR2/3/3A Rocker cover question Triumph 11
S MGB-GT Wanted: REMCO MG Rocker/Valve Cover MG 0
S TR2/3/3A rocker cover panels for the pre60K tr3 Triumph 1
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
B TR2/3/3A Questions about that rocker cover I "won" on E bay Triumph 6
M Healey 3000 a large of oil fumes fro rocker cover Austin Healey 14
stretchit2 Rocker Cover Austin Healey 12
M Moisture in Rocker cover Spridgets 5
P Valve/Rocker cover Austin Healey 5
T Minifin Rocker Cover Spridgets 3
64rocksprite rocker cover vs 1.5 rockers..fit? Spridgets 3
M T-Series Is a plugged TD rocker cover vent tube OK? MG 11
BritCarFan Rocker cover gasket help MG 19
A Rocker Cover Gasket... Spridgets 33
weewillie valve / rocker cover Spridgets 7
Lin Rocker cover rivets Austin Healey 3
wingsandwheels TR6 Alloy rocker cover, late TR6 Triumph 2
A Rocker Cover Paint Spridgets 9
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
WHT Rocker Arm Shaft Replacement Austin Healey 21
G Installing New Rocker Shaft Assembly Austin Healey 3
D TR6 Rocker arm assembly , pushrod clearance Triumph 8
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
kodanja TR2/3/3A Rocker studs for aftermarket Rocker covers Triumph 4
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
S TR2/3/3A All new valve train - no adjustment at rocker arms Triumph 12
M Rocker feed kit for 1500 from Victoria British Spridgets 0
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
Jim_Stevens For Sale New Rocker panels TR3A Triumph Classifieds 1
P TR6 Rocker panel hole Triumph 16
D MGB MGB rocker shaft shims MG 1
Lukens Outer rocker showing "rust" Restoration & Tools 11
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
D rocker arm assembly Austin Healey 14
Rut Replacing rocker assembly Spridgets 1
JimLaney Rocker shaft plug/screw delima Spridgets 3
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
matmire rocker arm stress cracks? advice please. Spridgets 2
red57 Outer Sill/Rocker fit problem Austin Healey 11
T Proper location for rocker shaft 'Screw-Locating' Spridgets 3
