Stripped Threads
SteveHall64Healey
On my BJ8, the lower bolt on the clutch slave cylinder stripped it’s hole in the bell housing. Any suggestions on how to deal with this - ideally without hauling the gearbox out?
steveg
Re: Stripped thread - any advice?
To fix properly, I'd be thinking heli-coil.
Wonder if this would work in lieu of pulling the trans: take an 8mm bolt and cut a couple of lengthwise notches with a grinder to make it into a self-tapping screw, then run it in with maybe blue or orange loctite.
Jack T
Steve, before you give up, try a slightly longer bolt. I thought one of mine had stripped but discovered the bolt wasn't reaching good threads.
vette
I agree with Steve. Heli coil ought to do it.
S
SteveHall64Healey
great suggestions everyone - thanks. I will try the longer bolt first, then try chasing the thread. If that fails resort to thread repair. What would be the advantage of a thread repair kit over drilling out the hole and starting a slightly large threaded hole - presumably with the next closest larger size?
Michael Oritt
Not a big issue, but you would have two different fasteners holding the cylinder in place. Now might be a good time to modify one of them by cutting off the head and making it into a pin to allow for easier removal/bleeding as while you need two to locate the cylinder on the housing you only need one to hold it in place.
Gliderman8
All good suggestions above! To add to the list, my choice of threaded insert is called a Keensert. Basically, it's a steel threaded insert that has wedges that are driven home to lock the insert in. Here's a short video.
I rethreaded my BJ8's bellhousing last time I had it out; previously, I'd made do with some 'make-a-thread' goop that worked well enough (those bolts aren't particularly stressed). IIRC, I used 'ThreadSert,' not 'HeliCoil' brand, which are equivalent. 3/8" 'fine'--24tpi if I'm not mistaken--bolts are used all over on Big Healeys, so it pays to have a kit handy (in particular, they're used for the front shock mounts, which are easy enough to strip). I use red (strongest) threadlocker on inserts, and I've never had one come out. Unfortunately, I don't think it's possible to drill and tap for inserts in situ.
Madflyer
There are four ideas given. Chase threads, longer bolt, thread insert, and making is a stud by cutting the bolt head and red threadlock it in. Access is the key I would make both the same. As a rule fine threads tend to strip in Alum. easley so having both the same and studs this can not happen again. Madflyer
S
SteveHall64Healey
These are all great ideas. However, I got lucky and a fresh bolt with blue threadlocker is holding well. Next time I have to service the slave cylinder, I plan to attempt to replace the thread with heli-coil or the like.
Steve
All the Healey gearboxes I rebuilt got this upgrade. Keeps the factory-spec'd fasteners too.
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
J Stripped threads engine block Triumph 7
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
davidk Stripped threads in oil pan front saddle block Triumph 12
M Block threads stripped torquing head Triumph 16
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Basil 7 Ways to remove stripped screws Restoration & Tools 2
B Stripped Thread in Gas Tank Austin Healey 26
G TR4/4A Well...another stripped trunnion Triumph 8
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
Johnny SU fuel pump banjo fittings stripped out Austin Healey 19
F New set of lug studs and stripped spines.... Triumph 12
P Stripped hood latch bolt Triumph 5
TRMark Being my own DPO, stripped front sealing block Triumph 6
L Stripped windshield frame screw hole Spridgets 6
K Painting a car not stripped to bare metal? Triumph 6
TRclassic3 stripped pan bolts Triumph 4
Lon_S Stripped a cylinder head nut Spridgets 7
DanNagy Spitfire Spitfire 4: Stripped Triumph 5
I Stripped screws in Bugeye windshield frame Spridgets 10
Tr3aguy Stripped and resprayed pics Triumph 4
Tr3aguy Stripped parts...yes Triumph 8
H Stripped headbolt Triumph 23
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
tinman58 TR2/3/3A stripped bolt TR3 Triumph 5
John Moore Big Milestone! Tub is stripped Spridgets 6
2wrench Help repairing stripped hole, rear overdrive case. Triumph 8
John Moore Front End Stripped and Questions Spridgets 20
R interal thread stripped on timing chain cover Spridgets 2
F GT6 GT6 differential mount stud stripped... Triumph 3
S Stripped bolt on timing cover Spridgets 17
Nunyas Stripped manifold bolts MG 4
drooartz I have a stripped Midget! Spridgets 16
B Paint Stripped..now Moss Motors or Victoria Brit? Spridgets 7
TexBug Stripped door hinge screw removal? Spridgets 4
T Question on primer after getting fenders stripped Triumph 16
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
Mark_Gibson Body Weight of a Stripped Down TR-2? Triumph 10
MattP Stripped Shifter MG 0
6 Stripped exhaust manifold stud Austin Healey 5
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
B Damaged threads in the gas tank Austin Healey 7
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
JimLaney Organizing threads into book? FORUM Navigation Questions 10
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
