TR4/4A Outer tie rods
bammons
I am having problems installing new outer tie rod end(s). I tried to install them with no real weight on the chassis (no engine, body etc) and used the measurements in the shop manual from the center of the rack and pinion body to the center of the tie rods. This did not seem to work at least on the passenger side (it made it too long). And I had lots of problems because of the steep angle to get it into the steering arm. Fast forward - I left it be until I got more weight on it. In trying to remove the passenger side tie rod to adjust it inward I destroyed it. So got a new one. Now the body is getting ready to be dropped onto the chassis to go to the body shop and I need to do something so the wheel is not flopping around. Of course I did not mark the original tie rod setting that makes it too easy. My chassis has all the suspension on it, motor, transmission, radiator etc on it now. Is that enough weight to accurately install the tie rod? I left the driver side installed from earlier (used the measurement talked about from above) but it seems to be rubbing on the dust shield. What do I do at this point? I've got about 10 days to do something before it goes to the body shop. It seems if there is not proper weight on it then when the weight is put on it it will push the wheels out. I'm lost Help. Bruce
Popeye
Bronze
TO be clear, your question is (1) how to install the tie rod ends, and (2) how to align them.
For 1, yes, weight is good. For 2, I'll let the experts chime in - but I suspect that after any suspension work, you want to have the front end properly aligned.
B
bammons
Yes My question is how to align them and do I have to have the car completely put together for the weight on the front end to be correct.
James A Martin
Bruce,
I am not an expert by any stretch... But, here is what I have done so far.
While on jack stands, I put a tight line on the back tire and got the front as close as I could to parallel on both sides adjusting the tie rod ends.
when the car was on the ground i checked the parallelism again.
I was able to rig a cheap laser level on the back wheel also, horizontally pointed at the front wheel, and take measurements on the front...between both methods and lots of worry this worked good enough for short tests with out wearing the tires and also got me to a garage that had an alignment expert and tools that I don't have to dial it in.
Jim
Mickey Richaud
It's always been my understanding that the car needs to be sitting on the ground, fully assembled in order to align properly.
Check YouTube for the string method of aligning - you can do this to get pretty close.
Sarastro
There's no way you can get it aligned right until you have the car entirely together and have full weight on the suspension. For now, just adjust things until the wheels are as close to parallel as you can get them; then it should be possible to roll the car around without problems. It's really not a big deal; it doesn't have to be perfect at this point, and actually can't be. Then, when you're ready to drive it, you can get a proper alignment.
sp53
They look about the same as tr3 to me, so install the tie rod; the body weight is not that much, and if it effects it a fuzz that can adjust-out
B
bammons
Ok guys - I visited with a forum member to get some parts and he showed me I was overthinking this and making it harder than it is. Steve you said the same thing he did - get it close so it can be moved around and it does not really need to be tight. After all the weight is on it then do it. He does the string method and it seems easy enough to me now that it has been explained. So thanks for your answers all were useful. Bruce
Sand bags to approximate what is NOT hung on the suspension. If you care to jump into this with both feet, find a used set of Dunlop Alignment gauges. AGO40. They were pricey when new in the '70s'. We've used that set to align the front-ends of everything from my personal Elans to Formula Ford and F-Atlantic race cars for decades with great success. A one-time investment for years of saving on alignment shop fees, too. And you could offer local LBC club members front-end alignments for a small fee. :wink:
Disclaimer: It can't do 'four-wheel" alignment.
tr6web TR6 Outer tie rods - TR6 Triumph 10
D TR2/3/3A 7.68, outer tie rod Triumph 4
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
tr6web TR6 Outer tie rod question - TR6 Triumph 5
Cain Lubing Outer Tie-Rod Joint/Upper Ball Joint Triumph 5
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
Lukens Outer rocker showing "rust" Restoration & Tools 11
B Outer steering column connection to the steering box Austin Healey 6
H General Tech Door Glass outer seals installation Triumph 6
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
F TR4/4A TR4 inner and outer sills Triumph 2
MisterB Outer structure repair order/checklist Austin Healey 9
S TR2/3/3A outer sill and fan tail Triumph 11
red57 Outer Sill/Rocker fit problem Austin Healey 11
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
M BT7 Outer Sill Replacement Austin Healey 2
H TR4/4A Outer door waist seal Triumph 5
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
S inner sills, outer sills, a post...where to start? Spridgets 28
I Sealing new outer panels on BN1 Austin Healey 10
O TR6 Outer Rockers WTB Restoration & Tools 0
O TR6 TR6 Outer Rocker Panels WTB Triumph 0
G OD of inner spring is tight to ID of outer spring Triumph 3
G excess wear on outer edge of front tires Austin Healey 13
M Photos of my outer sill repair Spridgets 11
M TR2/3/3A TR3 outer sill replacement Triumph 15
Jim_Gruber Looking for DS Outer Rocker - Front 4" Spridgets 9
hondo402000 TR6 TR6 outer sill replacement Triumph 2
germanmichel Fixing outer tube in steering box Austin Healey 11
K TR2/3/3A Paging TR3Driver re: trunnion outer washers... Triumph 4
J TR6 joining the inner and outer sills on a TR6? Triumph 1
G TR2/3/3A TR3 lower outer trunnion Triumph 4
M Outer Wheel Bearing - interference fit v Quality? Triumph 2
J TR6 Replacing TR6 Outer Rocker Panels Help Triumph 1
G Plan 9 from Outer Space Triumph 3
C How does one remove the outer door chrome? Austin Healey 2
A Outer sill replacement Triumph 2
