TR2/3/3A Tire pressure and ride comfort?
karls59tr
Bronze
What tire pressure do you guys run on your 3 front and rear. I realize this is up to the individual owner and how hard he drives the car but I would like to find the best compromise for everyday street driving so it's less bumpy. What did the factory recommend (different tires back then)? I have been running 28 psi front and rear but am wondering about having less tire pressure in the rear tires....how would that affect handling?:smile-new: What is the best compromise tire pressure you run?
CJD
I shoot for 32 psi front and rear. Less than 28 psi and she gets hard to steer in parking lots. I haven't tried more pressure.
bobhustead
There is a table at page 23 of Practical Hints for the Maintenance of the triumph TR3. This is the Owners Manual and can be found on Google (and I think Randall Young -TR3 Driver- posted it on this forum)
glemon
Though it is the opposite of what the factory recommends for most old MGs and Triumphs, I will run a higher pressure on the front than the back on old live axle LBCs. usually about 28 on the rears and 32 on the fronts. Theoretically a little higher in front to reduce understeer, and lower in the back for better ride and less wheel hop. Have not tried this one TR3, but have done it in a live axle TR4A, MGBs and Sprites.
DavidApp
I presume those pressures in that table would be for the old bias ply tires. Would they be different to modern tires regarding pressure?
I run about 32 front and back.
David
NeilRogers
Owners manual says for Dunlop tyres (assume these are bias ply) Front 22 psi and rear 24 psi.
For Michelin X tyres 24 psi front and 28 psi rear. Increase by 5 psi if car is driven consistently hard and fast.
Madflyer
Well the books call for this or that but that was in the 50's-60's-70's Todays tires have a rating that should be a starting point and that is a cold tire. Because of the foot print the high end number of the tire rating would be best but you may find it to be a hard ride. If you drive solo about town not a big deal. Summer with two people and luggage and highway speed add a pound or two to not over heat tire. Your spare should have the top pressure and tires over six years old come into question also. Todays tires come with not only the size but speed rating and date it was made and a DOT strip these are the factors of todays tires. And your life is on them. At a SCCA event I saw a driver say drop a 1/2 pond here and add a pound to the left side there that is fine tuning and you will need to do the same. Madflyer
Sarastro
Modern tires generally take higher pressures than the old cross-bias and even older radials. Dunno why that is, but it is generally true, based on recommended pressures listed in owners' manuals. So, the numbers in the TR manual don't mean very much. This is just one of those things you'll have to experiment with, but the responses above should give you guidance on where to start.
J MGB Tire pressure for 1980 MGB MG 14
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
K TR2/3/3A Optimum Tire pressure for a TR3 daily driver? Triumph 5
madhouse Tire pressure monitoring system [TPMS] for Healey? Austin Healey 0
tahoe healey Tire pressure again Austin Healey 59
NutmegCT T-Series tire pressure? MG 8
NutmegCT tire pressure gauge accuracy Restoration & Tools 21
NutmegCT TPMS - Tire Pressure Monitoring System Other Cars 9
sundown TR6 TR6 tire pressure Triumph 4
T TR2/3/3A tire pressure Triumph 18
bighealeysource Tire pressure recommendations for tubed tires Austin Healey 4
Nelson Autocross tire pressure?? Spridgets 4
R Glove box tire pressure plate Triumph 5
G Auto cross tire pressure Spridgets 7
Nelson Tire pressure Spridgets 10
1 Tire pressure MG 8
AUSMHLY Correct tire pressure Austin Healey 8
bighealeysource tire pressure with radials Austin Healey 11
D tire pressure question Triumph 8
wkilleffer Good tire pressure for 18570R14 tires on a '74 'B? MG 19
bighealeysource Tire pressure Austin Healey 2
jlaird Tire pressure Spridgets 5
jlaird Lets get serious=tire pressure Spridgets 18
TRclassic3 Tire Pressure Triumph 9
J Tire air pressure Triumph 9
S Tire Pressure and Additives Jaguar 16
A Dumb tire pressure question MG 9
MadRiver Tire pressure? Triumph 8
vping Tire pressure MG 15
C TR2/3/3A TR3A Tire Pressure Triumph 6
Brosky Tire pressure question Triumph 24
P Correct Tire Pressure for 165R15... Austin Healey 2
J tire air pressure MG 6
S TR2/3/3A Tire balance Triumph 15
T Tire Age Austin Healey 14
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Frameman 1949 Tire Options Austin Healey 16
T TR6 TR6 Tire Pressures Triumph 2
NutmegCT Tire pump in reverse? Restoration & Tools 5
prb51 BN6 Wheel/Tire Combo Austin Healey 26
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
F TR4/4A Tire saver ramp recommendations Triumph 10
D Wanted Austin healey Tire - used Austin Healey Classifieds 4
Bocaray TR2/3/3A Centred Tire Triumph 3
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
S For Sale Tire for Sale (155SR15) Triumph Classifieds 3
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
Mark Bailey Old tire rule? Restoration & Tools 5
