Removing the Jet assembly from under a SU carb. I am curious how other remove the Jet Assembly. I would like to leave the carb body on and then pull of the chamber and piston then undo the jet assembly. I am not concerned about the re-centering of the jet at that point, but more about getting a good seal on the base of the carb. I remember in posts where people would slide the jet out to polish it.
Maybe pull the jet back as much as possible like the choke is out and then run the adjust nut up kinda tight and then undo large 13/16 nut with the cork seal and the carefully reinstall the whole assembly.
Looking for ideas
Looking for ideas
