Side Screens
Healey Nut
Does anyone know what the purpose of the hole is on the outside of the front angle of the frame? It’s close to the top front corner a couple of inches from the top.
Also I’m not a purist so I’m trying to decide which knob to use to secure the side screens.
The 62 should use the regular wing nut type last pic (which are fairly ugly IMO) I think the thread is 5/16th UNF.
Im thinking of an alternate but need to know if the thread size is the same on either .
The four star knob (as used on Longbridge cars I think).
The knurled knob for the folding windshield.
The single wing type.
See pics.
Suggestions anyone?
Rob Glasgow
Re: Side screens .
Not sure if this is the hole you're referring to, but it's only about an inch below the top. On the outside it had no purpose but on the inside edge, it holds the little rubber bumper that is supposed to keep the side curtains from rattling. You can see the bumper on the inside shot. I happen to like the double wing nuts that hold the curtains on. They have a real smooth and substantial feeling to them. That sound weird now that I say it. Sorry the photos posted upside down.
Healey Nut
Healey Nut
Re: Side screens .
Tks Rob .
that makes sense it would be for a little rubber bumper .
Im just not a fan of the standard wing nut and seeing as I will rarely use the side screens I want whatever is on the stud while the side screens are not in use to look appealing .
British_Recovery
Bronze
The small hole on the outside of the side curtain frame is for a small round head Phillips sheet metal screw to hold the rubber bumper in place.
John Turney
Since I have a Longbridge car, I'm partial to their fixing nuts:
One advantage of them is they are smaller than the later wing nuts. The threads on both are 5/16, with the rear one being coarse and the front being fine.
I'm also partial to the original Longbridge brackets.
Healey Nut
Healey Nut
That looks way better than the regular BT7 wing nuts .
I see your brackets are chromed , is that how they were on Longbridge cars .
the brackets on my side screens look the same but no chrome plating .
John Turney
Mine had poor chrome on them when I bought the car. They've been re-chromed. The photos in the Restoration Guide are not really very good, but they look chromed, so I would say they should be chromed.
The later rear bracket is just a simple plate, bent to go around the aluminum trim, and I've never seen them chromed.
John Turney
Since you are not into concours originality, it probably wouldn't matter, but the Head-4-Healeys star nuts look like a DIN6335 palm grip. Attached is a comparison of an original star nut (top) to a stainless DIN6335. The threaded hole in the DIN6335 has not been drilled and tapped yet.
Healey Nut
Healey Nut
The DIN6335 would work for my liking and I would blind drill and tap them instead of all the way through .
Healey Nut
Healey Nut
You would have to check if you can get the side screen tight enough without threading all the way through.
That’s an easy fix , just shorten the bracket threaded section to suit .
Deleted member 21878
or use a spacer. using a spacer may allow you to adjust the side screen in or out a little for better fit.
once you know, you can cut if that works better.
Fanch00 Noisy Side Screens Austin Healey 13
C Mk1 3000 side screens variations Austin Healey 13
andrea 100/6 side screens Austin Healey 7
BN6_2197 Storing side screens in a BN6 Austin Healey 4
BN6_2197 Correct alignment of BN6 side screens Austin Healey 11
Trevor Jessie Refurbishing side screens Spridgets 4
K TR2/3/3A Side view mirrors again Triumph 7
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
Walter74 AH Spares Side Exhaust Austin Healey 2
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
HealeyRick BJ7 Side Window Alignment Austin Healey 31
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
madhouse 100-Six Side Curtains Austin Healey 8
R MGA MGA Headrest fairing for R/H side MG 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
S TR2/3/3A foot well driver side carpet Triumph 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR2/3/3A tr3 side curtains Triumph 4
R Wanted 100 side curtains Austin Healey Classifieds 9
C MGA Side curtain info MG 11
HealeyPassion Works Rally Side Vents Austin Healey 24
S Wanted Side Curtain Retainer for Swallow Doretti Other British Classifieds 0
Sopwith_Camel MGB wirers are greener on the other side? MG 4
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
Got_All_4 TR6 Differential side hub measurement Triumph 1
PAUL161 T-Series TF Side curtain storage in compartment MG 3
