77MidgetMkIV
Hey all- not a big poster as of late, but figured I would kick one off for this spring's Midget projects- It started innocently enough- I pulled the steering column to replace the High/Low/Turn signal switch, and while I was at it, I decided to clean up some loose wiring, and make a parts list- new column cowl and ignition/keyset (mine are not original and not even actual MG)....I then decided to finally pull off the old soft top, as it was torn, and remove the frame since it had a broken bow that I have dealt with for years- I have another one I've stored for over 15 years, finally going on the car. Then I pulled the seats to get a good vacuum on the entire carpet.....then I pulled out all the carpet and will replace it w/ new.....and all the panels....I can't stop! I've owned mine for 22 years, and it is finally getting a makeover!
