TR6 Source for fuel line P-clip
steveg
Has anyone got these? No Moss or TRF number.
poolboy
It's kind of below the T-stat...It's on one of the bolts for the water pump housing.
You can see the head of that bolt and some of the clamp in this picture.
Looks like it would be easy make.
TRopic6
Steve, I ended up with several; usable but with surface rust. Lately I've been refurbishing 6RA relays; soaking the cases in 6% vinegar for 24 hrs gets rid of most of the rust (but not the patina). I can round them up to see if they're better than what you have. Jeff
Tybalt
You might take a look at McMaster-Carr, search under "p-clamp" or if you want something that provides better vibration damping under "adel clamps." Aircraft Spruce is another good source for stuff like this.
Madflyer
I have a few but nothing like new I would say soak yours in Coke Cola for a time should shine up or paint. Madflyer
steveg
steveg
Thanks - checked out McMaster-Carr. This clamp looks like a one-off. Maybe that's why the usual suspects don't stock it.
Tybalt
Going back to my crusty old parts catalogs, the Triumph part number for the clip is 138516 and the sleeve that fits in the clamp and cushions the fuel pipe is 114178. As near as I can tell the 138516 clip is NLS (no longer supplied/serviced) but the 114178 sleeve is still available.
IIRC, that fuel line is a -5 (5/16" OD) and it looks like the ID for the cushioned clamps from McMaster are all for -6 tubing (6/16" OD). They do have an uncushioned one that is 3/8" ID so some thin rubber sheet (1/32" or so) material could be cut as a cushion sleeve. If you scroll down past the illustrations, the Aircraft Spruce catalog has a link to a copy of MS21919 that you look over for all of the material codes covering the clamps and cushions, dimensional information and wedge vs nonwedge clamping types under Documents, Tech Data Sheet:
https://www.aircraftspruce.com/catalog/appages/ms21919clamps.php?clickkey=34954
TRopic6
I found these in my spare stuff box. Not sure if they're better that what you have; should clean up OK. Just the shipping if you want one.
Jeff
Tybalt
5/16" from the fuel tank to the pump, but 1/4" from the pump to the TR6's carbs
Went back and did a little digging and sure enough the hard lines from the pump as well as the hoses should be -4. Having said that, it looks like at some point early in my TR6s history, the hard line from the pump up and around the front of the engine was replaced with -5 tubing with the last bit of hard lines and the tee fitting that splits things off for each carb being -4. I guess I never gave that -5 tubing a second thought since it was so well done that it looked like it had always belonged there. This was on the engine that was in the car when I purchased it. That engine was removed from the car and is just sitting around in storage.
The car now has an electric pump with fuel pressure regulator and a combination of -6 hard lines and braided flex lines feeding the carbs and a different TR6 engine that has been modified a bit.
Dr.T
I just made a new one from some sheet metal, and I’m no fabricator, so it’s pretty easy. After fabrication, I zinc plated it. Looks pretty good. I’ll try to post a picture when I get home. Ordered the rubber piece from TRF, but it’s just a piece of rubber hose you could get at the auto parts store.
CinneaghTR TR4/4A Best Source for 4/4A Pump to Carbs Fuel Line? Triumph 21
Bruce_B Source for brake line/fuel line clips Spridgets 7
I TR6 TR6 fuel pipe nut source? Triumph 5
PeterK Fuel pump screen & gasket source Triumph 6
A Spitfire Source of replacement Spit fuel tank? Triumph 2
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
J TR4/4A TR4A rear wheel cylinder source Triumph 3
I Bigeye transmission source? Spridgets 7
Rut TR4/4A Good interior source Triumph 29
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
Jim_Gruber Source for Small U Bolts on 1/4 Elliptic Springs- Spridgets 11
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
Csarneson Source for BN4 2nd Gear Austin Healey 8
CJD TR2/3/3A Source for Horsehair Padding? Triumph 10
Michael Oritt Rear upright casting--source needed Racing 4
I TR6 Under bonnet sticker source Triumph 3
