TR4/4A Fenders off the car for paint?
tdskip
I believe the answer is that yes, fenders should be painted off the car, after fit issues have been addressed but I wanted to ask. This is for a 1966 TR4a.
Marv - figured I might as well push this project ahead while I continue to look for big Healeys.
thank you in advance for any coaching, hope everybody’s having a good weekend.
M_Pied_Lourd
Hey Skip! Yes, I do my fitting up first and then take them off the car to paint. Now, if I were doing a metallic paint instead of a solid colour, I might rethink that approach.
Cheers,
Tush
sp53
Marv has a lot of experience. I would say yes, and if needed you can put some blue tape on the area you fear might get bumped in the reinstallation. But I would guess it depends on if the color is a good match and how much further you want to get into the car. There could be some more work behind the fender.
steve
T
tdskip
Thanks for the responses, and suspect it might be a tad warmer here than where you are Chef.
This is a Royal Blue car, going to stay Royal Blue so fenders off it is! She hasn't been apart before, too bad I can't save the original paint but there is some scab and a big fender in the fender so time to suck it up and get it done.
M_Pied_Lourd
Winter hasn’t been to bad so far up here and we are almost half way through it so I’m happy about that.
I’m currently painting my TR250 in Royal Blue. Couldn’t find anyone locally to mix the factory Royal Blue formulation so I’m going with a Chrysler colour called Nightwatch Blue. It seems to be pretty close to the original royal blue that’s still left on the car.
Cheers
Tush
Tom,
I fit the fenders, do any body repair needed, remove fenders,doors and paint the underneath (same with tub) reinstall the fender/doors for exterior paint. Same for trunk and hood. I use single stage paint on the underneath panels. I take it to the paint shop for the finish paint in base clear. I can spray a decent coat on tub inside and underneath panels but don't attempt the finish. Saves quite a bit on the cost of painting. I probably put a lot more paint on the underneath panels thans needed but I feel it seals it from rust more.
mctriumph
Drum roll, THE most important thing when the front wings are off. You must replace the scuttle drain hose
with a longer unit that will reach the bulkhead plate at the rocker. Drill a hole in the plate for the drain
to release water OUTSIDE of the inner fender. Caulk the hose in place with urethane.
T TR6 Got the rear fenders off the TR6 Triumph 11
B Paint Fenders on or off? Austin Healey 5
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
SNClocks Gap between inner and outer fenders Spridgets 0
J Best Aluminum Fenders? Austin Healey 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
R 100-4 rear fenders Austin Healey 6
rjc157 For Sale tr6 fenders Triumph Classifieds 0
rjc157 TR6 Rear Fenders Triumph 1
S TR2/3/3A caged nuts on the fenders Triumph 9
maxwedge5281 fenders Austin Healey 24
T TR6 Painting the car with the fenders on Triumph 7
K Tricks or Best Way to Install Front Fenders? Austin Healey 14
T Kilmartin rear inner fenders Austin Healey 2
N What size wheels and tires for flared fenders? Spridgets 7
rustrocket TR6 Looking for TR6 flared fenders... Triumph 9
A TR2/3/3A Mounting Front Fenders Triumph 5
Patrick67BJ8 Insulating Rear Fenders Austin Healey 6
Patrick67BJ8 Sealer between fenders and shrouds Austin Healey 12
6 inner fenders wanted Triumph 4
B Fenders for sale Spridgets 10
J why they say don't buy replacement fenders! Triumph 4
KVH New Fenders Triumph 6
T 100 Fenders Austin Healey 0
D Fenders Austin Healey 13
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
Tr3aguy Source for rear fenders Triumph 7
H Transportcompany for shroud and fenders Austin Healey 0
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
Brinkerhoff TR6 TR 6 rear fenders Triumph 1
RickB Needed - early Spridget fenders Spridgets 5
Marvin Gruber TR6 TR6 Fiberglass fenders Triumph 3
D MGA MGA Fiberglass fenders MG 3
J AH 1962 - Putting on Front Fenders Austin Healey 8
T TR4/4A What to do with these TR4/TR4A inner fenders? Triumph 7
mrv8q TR6 TR6 74/74.5 Fenders Triumph 1
E fenders for 1968 sprite Spridgets 5
subnet_nd Fiberglass fenders Spridgets 2
hondo402000 painted fenders Triumph 18
TR3MT Removing rear fenders Triumph 10
Number_6 TR2/3/3A Removing front fenders on a TR3 Triumph 20
J Austin Healey - painting fenders Austin Healey 6
J Removing Fenders on Austin Healey MKII - 1962 Austin Healey 14
T TR6 width comparison tr6 vs tr4 at fenders? Triumph 1
bighealeysource removing fenders on a BJ8 Austin Healey 2
rlandrum Flappy Fenders Triumph 4
chrpark mangled inner front fenders Spridgets 6
S TR2/3/3A tr3 rear fenders Triumph 8
H Fenders/wings question Austin Healey 4
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
