TR4/4A shining up thermostat housing
Twit
I'm reassembling my TR4 and the thermostat housing looked shoddy so I put it in my tabletop sandblaster. Now its just not as shiny as the other half. It looks like there is some kind of glaze applied to the metal parts. Can someone tell me what I should spray on the housing to bring it back up?
thanks Dave
CJD
Some castings are such low grade metal that they cannot be polished. I think you found one. Silver paint would likely be the best option. That's what many rebuild shops do with aluminum parts.
charleyf
. Had mine powder coated a silver color. Over ten years ago and still looks great.
Andy Blackley
Have you tried metal polish..by hand ?
That's the ticket. I removed the POs black paint and heavy dirt with a wire wheel and then a Dremel to get into the nooks and then a lot of hand work with metal polish and super fine steel wool. A power buffer after that would really shine it up. I didn't do that, as can be seen in the attached photo. Not show quality but OK by me.
Twit
Twit
I pulled out an old can of brasso. The housing looks good but still not matching the other half. I'm going to just sandblast the other piece of the housing and brasso it so they match.
Madflyer
On my TR 6 I had the same problem polish wet dry 600 sand paper nothing seemed to make it polish up. I bought a new one and it came up bright with polish and buffer wheel. I also have an Alum. valve cover the look matched now. Madflyer
Andy Blackley
Isn't that fuel filter supposed to be installed the other way around???
No sir. You can't see it in that photo but there is an arrow on the clear part showing the direction of flow. You want the dirt and debris to be trapped on the outside of the filter media where you can see it.
Twit
Twit
Ultimately I realized I had another in my spares pile so pulled it out and gave it a gentler cleaning up. It still has its shine.
thanks Dave
jaybird Sun's shining, top's down... MG 35
K TR2/3/3A Further to "plugging the thermostat bypass hose"/ Triumph 25
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Lin Thermostat and blanking Sleeve question again Austin Healey 7
R TR2/3/3A Thermostat and bypass hose Triumph 15
T TR2/3/3A Question on TR3 thermostat from TRF Triumph 6
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
AUSMHLY BJ8 Thermostat Austin Healey 4
Healey Nut Thermostat blanking sleeve Austin Healey 13
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
D BT7 Thermostat Austin Healey 1
D BT7 thermostat gasket Austin Healey 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
C Corrosion of the thermostat cover Austin Healey 8
R TR2/3/3A Correct Thermostat? Triumph 7
O TR2/3/3A Thermostat housing Triumph 3
AN6-TX 948 Thermostat Housing Spridgets 11
S TR2/3/3A Bellows thermostat for tr3 Triumph 11
steveg Robertshaw sleeved thermostat Austin Healey 3
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR2/3/3A used thermostat Triumph 5
B TR6 Which thermostat TR6? Triumph 3
P Overheating after shut down & recommendation on thermostat Austin Healey 3
R correct thermostat Austin Healey 3
steveg Thermostat questions Austin Healey 44
R Thermostat revist Austin Healey 11
T TR2/3/3A How do I remove temp gauge capillary end from thermostat housing on TR3A? Triumph 8
R looking for Moss 363-370, 1500 thermostat housing Spridgets 13
KVH Thermostat Housing Gasket--Must the Sealant Dry? Triumph 3
J TR4/4A TR4a Thermostat Triumph 2
GBT remove thermostat MG 11
K TR2/3/3A Who is running a Sleeved Thermostat in their TR3? Triumph 16
Anthony_S Thermostat Triumph 4
M 99 XJ8 Thermostat Housing Failure Jaguar 0
Skip_Shervington TR2/3/3A TR3A Thermostat Housing Leak Triumph 6
Morris Thermostat vs. Pinging Spridgets 14
R TR4/4A Tr4a, what engine thermostat for San Diego Triumph 9
M Headremoval and thermostat.. Austin Healey 3
R Need more heat - which thermostat MG 15
RJS Thermostat Stuck Open? Triumph 11
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
rlich8 TR4/4A TR4A Thermostat Bypass Triumph 5
BugeyeNJ58 Geo Metro Radiator - need thermostat housing Spridgets 10
Westfield_XI What if the thermostat was in upside down? Spridgets 9
D Thermostat Austin Healey 37
T TR2/3/3A TR3 thermostat rating Triumph 4
M T-Series Thermostat Switch Question MG 11
BugeyeNJ58 Thermostat question - is it needed in hot weather? Spridgets 5
