TR2/3/3A Facia removal steps
dmm7132
Hello all,
I am about to begin removal of gauge panel and the facia panel for refurbishing, do any of you have a step by step procedure by chance? Thanks in advance for any help you can provide)))
Dennis
sp53
I have removed a few. If you are doing a total restore, and taking the main dash out, it might be easier to leave the center in place, kinda. Plus like everything it depends. Are the gauges all in and the glove box in? I would unhook the oil gauge on the firewall and if you have a stock temp gauge take special care with that and soak the thermostat housing in your favorite loosener. To provide maximum help I would need pictures of the assembly. Oh and it will be enjoyable if you let it.
steve
LarryK
Take pictures in process, easier to put back later.
Jim_Stevens
John in Texas posted a step-by-step leather recovering for his tr2. I Followed it to the letter. I had Nisonger rebuild my gauges and used a crinkle-finish powder coat for the center section. I would take pictures as to wiring harness routing, and save the bronze wing nuts!
doakley Spitfire Removing facia Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
S TR4/4A Metal facia trashed Triumph 3
Darwin Spitfire dash facia Triumph 0
E TR4/4A TR4 Wooden Dash Facia vents Triumph 13
Russ Austin New Facia Installed Triumph 5
martx-5 TR2/3/3A TR3 Dash [Facia] Triumph 12
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
BoyRacer Door Skin Removal Austin Healey 6
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
C MGB Rubber Bumper cover removal MG 5
kodpkd Antenna Removal Austin Healey 9
B General MG Crankshaft Nut Removal MG 4
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
W BN1 Steering Box Removal Austin Healey 11
S TR2/3/3A engine removal Triumph 12
S TR2/3/3A Steering wheel removal. Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
C MGA Dash removal MG 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AUSMHLY Spigot Bush, Pilot Bushing Removal Austin Healey 4
R TR2/3/3A Steering wheel hub removal Triumph 11
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
D Heater knob removal Spridgets 6
S 1275 oil pan removal Spridgets 30
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
E austin van heater removal Other British Cars 0
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
nevets Water Pump Removal Austin Healey 6
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
F Interior Door Handle Removal Austin Healey 2
Z Front Springs Removal Austin Healey 3
R Oil Filter Removal Austin Healey 1
C MGA R/H tail lamp removal on a 1962 MG 5
K TR2/3/3A Removal of tie rod end? Triumph 7
J Ignition Key Cylinder Removal Austin Healey 3
J Planetary Gear Removal Austin Healey 3
Walter74 Adjustable steering wheel removal Austin Healey 4
E MGB 1965 mgb fuel pump removal MG 2
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
T BJ8 Drain Channel Removal Austin Healey 2
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
pkmh Front Spring Removal For BJ8 Austin Healey 8
