TR6 TR6 Differential Rebuild question
Jerryny
Morning all,
I have a 73 TR6. The differential is making a small clunking sound when its rotating The car is up on stands and both axles have been disconnected. I am wondering if anyone knows of a quality shop that rebuilds triumph differentials. I'm near Albany NY, but am willing to travel to NJ, Conn, Mass.
Thank You in advance.
Jerry
J
Jerryny
Thanks. There is also a place called britishmotorsltd in Ct that does engine rebuilding, transmissions and a whole host of other things.
Madflyer
Is the clunking when rotating back and forth if so it is just the gears to lose and can add add shims to set gear lash to 0.004 0.006 check in three places on gear. If the flanges slide right off then they are broken at the key way and seals are most likely bad also. There is no drain plug and you can do that at the same time on the end cover. Madflyer
Rod-H
Bronze
Plus One on Quantum Mechanics, they did a great job on my TR4 rear end.
Rod
poolboy
It clunks all while it's rotating or just when the rotating first begins ?
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
SkinnedKnuckles TR6 TR6 Differential Rebuild Triumph 4
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
L Wanted Tr6 differential Triumph Classifieds 9
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
T TR6 TR6 Differential Ratios Triumph 8
glemon TR6 tr6 differential seal Triumph 10
W TR6 TR6 Differential Question. Triumph 6
MTribe TR6 TR6 differential leak fix - what to do? Triumph 11
mgedit TR6 TR6 Differential Mounts Triumph 6
K TR6 tr6 differential - need feedback! Triumph 16
J TR6 Last TR6 differential question Triumph 16
R TR6 TR6 differential internal upgrade Triumph 0
H TR6 Tr6 differential backlash Triumph 2
Aeroken TR6 TR6 Differential Inner Shaft Seals Triumph 8
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
tr6web TR6 DIfferential and support damage TR6 Triumph 20
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
