Toyota 5 Speed - Truck or Supra?
HealeyRick
I did the Smitty conversion about 15 years ago and am thinking of selling the kit and 5 speed. I've been asked whether I have the truck or Supra tranny and I don't have a clue. The engine and tranny are out of the car and are connected as a unit. Can I determine which one I have by rotating the crank while the tranny is in first gear and counting the revolutions on the output? What should the count be on the output shaft?
roscoe
The gear ratios will tell you which box you have . There is also a good page on Wikipedia that lists the major differences between all the W series Toyota gearboxes. The other question you may get is whether or not the "sandwich plate" is steel or aluminum alloy. The steel sandwich plates are usually black and are obviously magnetic. The steel plate boxes have some larger bearings and gears but either box is more than enough for any of our purposes. They are getting pretty hard tto find compared to a decade ago so it may be worth more than you think.
CraigC
The W58/Supra is the only W-series box with a 0.78 5th gear. All others are ~0.85.
Simplest way to differentiate is to rotate the input shaft with 5th gear selected.
Put a mark on the output shaft to allow easy counting. To turn the input, use a clutch disc that has a "counting" mark on it or a set of locking pliers (and something soft to protect shaft) on pilot section of input.
Rotate input, counting the turns as you go, while someone counts 10 rotations of the output shaft. This should take a little over 7-3/4 turns of the input for the W58/Supra box. If it takes ~8-1/2 turns it is not a W58/Supra box. The reason for recommending 10 turns of output is that it is easier to differentiate between 7-3/4 and 8-1/2 than between 0.78 and 0.85 turns at the input shaft.
There are differences in the 1st gear ratios of the non-W58/Supra boxes, so performing a similar test should allow differentiating between the various non-W58/Supra options.
Cappy
How can i check with transmission connected and in car?
BoyRacer
If you are hitting your elbow on your seat back when you shift into second or fourth you most likely have a Supra transmission. If your stick comes up in roughly the same place as a BJ8 centershift transmission than you have the truck box.
Michael Oritt
Richard--
I don't think that is a good test as there are different tower options on all the boxes.
roscoe
I have a W58 and there are 3 available shift tower/linkage locations. I am not sure but I think most of the W series gearboxes are changeable in that way.
BoyRacer
Yes, there are different tower locations. But, in order to change the location you have to split the transmission and purchase different connecting links and a different tower. It's not complicated but then again it's not an easy changeover and I doubt many people have attempted it.
Every W59 truck transmission I have ever seen has the tower in the most forward position. Every W58 Supra transmission I have ever seen has the tower in the #3 rearward position. (There are actually 5 different stick positions with the W series transmissions, two or which extend beyond the back of the tower - but those are in different models. )
roscoe
I think all you need to do to change shift towers is have the shift lever and tower set that you want to install, pop the 6 bolts that secure the shift tower and remove the tower with the old shift lever and drop the new one in. The rubber oil barrier gasket has to be changed but they are readily available from the parts houses that sell transmission parts. No need to drain the oil or remove the gearbox from the car. Unless, of course, there is something I'm forgetting.
BoyRacer
So Jon, what makes you think it is that easy? Do you think I just made that up about splitting the transmission in order to change out the shift linkage?
Michael Oritt
When I bought my (truck) transmission from Smitty he offered me the three options for locating the shift tower. I chose forward-most and it is, to my mind, the best location as the stick lays properly to hand.
The 3000 I purchased for my ex-wife has the stick in the central location and it is not near as handy as the forward-most option.
dajamies
While you are playing around in the shift tower, inspect the conical spring and fiber washer. Replace the washer if it showws any wear. Email me directly for pictures and a full explanation of my shifting troubles and cures. dave.jamieson@bell.net
roscoe
Richard, you are correct. Had you reminded me that there is a need to replace the shifter yoke I would have recalled that I did that when I had the tail housing off to change out a worn speedometer drive gear. I don't suspect people make things up on this forum, but I have seen "misremembrances" before and I apparently just had one. Drain the oil you must, and remove the tail housing. Therefore the gearbox has been removed. Pulling the tail housing is pretty easy to do on the bench as long as you rember lefty loosey, righty tighty.
BoyRacer
Jon, thanks for the correction. It's not the first time someone has posted the notion that only the tower needs to be changed. I'm attaching a photo showing some different length arms that are hidden inside the tranny. These arms have a socket on the end for the shifter stick. The arms are attached to a shifter rod and held on with just one bolt. There are at least 5 different length arms (and towers) used in the W series transmissions for Toyota's various models.
roscoe
Well, I've answered a very important question for myself. I have an excellent memory, it just happens to be good for about 8 months or perhaps a bit less, because that is how long ago I did that conversion. I had the tail housing off to change the speedo gear and of course slipped on the new link at the same time so it took zero extra time and was not the original reason I pulled the tail housing off, as I changed the speedometer drive gear before I actually had the kit from Delaney but didn't put it together until I had all the parts.
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
Michael Oritt Toyota 5-speed Problem Austin Healey 28
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
M Toyota 5 speed Shifter Austin Healey 2
M synthetic fluid in a toyota 5 speed? Triumph 20
prb51 Tr Toyota 5 speed upgrade Triumph 24
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
gsalt57tr3 TR2/3/3A 5 speed Toyota transmissions in a TR3 Triumph 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR6 Toyota Transmission conversion Triumph 8
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
aeronca65t One less Toyota 2000 GT Other Cars 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T TR4/4A Toyota calipers for a TR4A Triumph 18
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
