TR2/3/3A Steering Box end play
Jayplum
I understand the process to set the end play.
Is this possible without removing the assembly?
I have a ‘57 small mouth with a one piece column.
The box was gone through by me prior to my further education on this measurement, i.e. new bearings, etc. In addition suspension and steering all refreshed.
I have approximately 2” free play in the wheel and have already tightened the set screw for the Pittman shaft.
Bottom line is procedure; can this redo in the car?
CJD
Only if you are able to disconnect the steering assembly from the drop arm. The preload you are trying to set for the steering shaft bearings is so slight that you would not be able to feel it with the steering connected. In fact, it will be extremely difficult with the steering wheel installed too. You are trying to feel a few inch-lbs, by trial and error with shims, while the steering and wheel are adding ft-lbs to the "feel". Even then, you will be working upside down on your back, adjusting shims on the end plate while the outer bearing is trying to fall out every time.
If you have 2" of play, your issue is not likely the bearing end play anyway. Chances are your peg and/or worm gear are worn. Those are not repairable with the unit in the car. The peg wears at least 10 times faster than the worm, so a new peg will likely solve your problem.
I'd recommend waiting until you have time to do it right. It'll be less total time that way, with far less grief.
Jayplum
Jayplum
Thanks. I’ve ordered a new peg and will probably pull the shaft over the winter.
Just looking for a short cut. Even though they seldom work.
titanic
I remember buying a TR3 that had a gross amount of free play in the steering. The culprit was the silent bloc bushing (Moss #667-040). The rubber bushing had deteriorated to the point of non existence. Other culprits ( as John mentioned) are the peg and wear in the idler.
Berry
sp53
If I remember correct, to unhook the bar to replace the silent blocks you would end up freeing the idler arm and the steering box from the steering. That way you could replace the silent blocks and the idler arm and get a better feel for just how much play there is in the steering box. So if you have not done that--- that is what I would do.
steve
Jayplum
Jayplum
Thanks. All steering has been replaced. I did use the standard silent blocks and did not up grade to the more secure one’s offered by moss (not sure if those would have been better).
I began with 3”+ ; the tightening of the pitman arm brought her to 2”.
I believe John is correct and will pull the column and do a full inspection on the bench.
I have believed in doing it right the first time but me learning curve on a ‘3’ did not keep up on this one.
Jayplum
Jayplum
steve
thanks I believe all that is ok but it certainly will be inspected carefully as I disassemble
Walter74 Steering Box End Play Austin Healey 2
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Checking steering box End Play? Triumph 5
ekamm TR2/3/3A Tr3 steering box end plate Triumph 8
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
A replacing steering box leaking end gasket Austin Healey 1
P steering box end float Triumph 3
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
J Experience with High Ratio Steering Box? Austin Healey 15
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
simon1966 Steering box lubricant Austin Healey 17
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
