TR2/3/3A Girling Rear Brakes
Redoakboo
I am finishing up the restoration of my 54 TR-2 Long Door. I found out, while working on the rear brakes that the previous owner had upgraded to a Girling Rear end. I have new cylinders, pads partially installed. I installed the upper retainer pin with spring and washers. Question.Looking at the Moss catalog I see a different retainer with it's pin. How is this attached and where?
Dick
sp53
With the 10 inch brake drums, the shoes are held in place with the arrangement of the springs that hold the shoes in place together on the adjuster. The 10 inch does not use keepers with a rod and cup. Instead they only have a small stud on a screw from the back about in the center of the shoe that turns in and out with a felt pad on it to get the shoes perpendicular in the drum
steve
R
Redoakboo
Do I need those retaining clips, Moss shows 2 per pad, rather then the keepers with a rod,spring and caps? I have the 10" drums. I see the screws, but the felt pads are history.
You don't have a pic of this setup do you> None of the manuals or catalogs show it.
I have the pads and springs back installed and are waiting for the felt covers before I re-attach the brake drums. Is it correct for the brake pads to lean outwards? Is it just the drum that alighns them?
Dick
sp53
I looked and do not seem to have a picture either. They used the 10 inch 57, 58, and I think part of 59. There really is no keeper just the stud with a holding nut and the felt pad that is often missing. Anyways, when the springs are installed correctly in behind the shoes, the shoes with bend inward and can be pushed out with the little screw and felt until the shoes fit nice. At least that is how I remember it.
If you have not put the springs on in behind the shoes, place both shoes with the springs in back on the floor then grab the shoes with both hands and stretch the entire assembly at the same time over the axle lug nuts while keeping outward pressure so everything does not fall loose . You probably will need to fettle with it some to get it over axle
Does the Moss catalogue show a picture of the springs? I have seen a picture somewhere, but it has been awhile, and I will look through my books. Do you have a large original copy of the tr2 and tr3 book that should have a picture? Usually the shoes themselves are too large to fit nicely in a 10 inch drum probably because the shoes are aftermarket; you might need to fix that.
Keep us posted steve
R
Redoakboo
I think you hit the nail on the head. I have the springs installed on the front of the pads , not the back. Now I see how that stud, with the felt pad, can be used to push the pads outward to alighn them.
Thanks again, Steve
sp53
Dick did you get the brake problem figured out? I am curious if I remember correctly. I consider the forum therapy for a declining memory and vicarious living to help stimulate my cognitive place in the universe.
steve
R
Redoakboo
Steve,
Your memory is excellent.I took those spring pins off relocated the pad springs to the back and now I am just waiting for the 4 pads to put on the adjusting screw. Those pins were also keeping the emergency brake from working.
Dick
R
Redoakboo
Steve,
Dick
Steve, With a Girling rear end, how do I adjust the rear brakes? No problem with the fronts.
Dick
sp53
Turn the large square bolt on the back of the backing plate. This moves the pointed cam to expand or shorten the distance and open or close the shoes. make sure you make a full turn so you are not stuck on a high spot of the came.
R
Redoakboo
Thanks,
Dick
TR4nut TR2/3/3A Girling 10" Rear Brakes question Triumph 29
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
jfarris TR2/3/3A Changing rear wheel studs in a later Girling axle Triumph 3
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
J TR2/3/3A TR3/3a Girling rear axle... Triumph 4
A Wanted Girling Axle for TR2 Triumph Classifieds 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
algot1901 Girling Brake adjustment Other British Cars 2
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
Lin Girling Master Cylinders Austin Healey 5
S General Tech Standard for the Girling Bubble Flare Triumph 15
S T-Series girling shocks MG 0
K TR2/3/3A New TRF Girling 9" brake drums compared to orginal Triumph 3
R Girling vs other wheel cylinders Austin Healey 10
2 TR2/3/3A Girling axle disassembly for shipment Triumph 6
H Problems with Girling master cylinder Austin Healey 8
T TR2/3/3A Bench Bleed Girling Master Cylinder Triumph 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
K TR2/3/3A Girling Clutch MC Mystery? Triumph 2
Andrew Mace TR2/3/3A TR2/3/4 Girling front shock ID? Triumph 1
D Girling replacement booster Jaguar 0
K The Girling Company? Triumph 5
K TR4/4A TR4A Girling Brake Caliper Taken Apart? Triumph 3
K TR2/3/3A Girling 10" Brake Backplate TR3A? Triumph 1
R TR2/3/3A TR3A Girling Brake Callipers Triumph 7
HerronScott Lucas and Girling Triumph 3
deadair TR2/3/3A TR3A -- Vacuum Bleeding Girling Brake System Triumph 13
H Rebuilding Girling 16P Triumph 5
K Girling Brake Mas Cyl Kit SP 2151-2... .70 or .75 Triumph 0
hondo402000 TR6 TR6 clutch master cylinder arrived[not girling] Triumph 5
BOBBYR Girling brake booster Austin Healey 5
P Girling brakes on a Chrysler? Other British Cars 8
angelfj1 Girling Brake Calipers - Resleaving with SS Restoration & Tools 4
Z Girling/Armstrong lever arm shocks Spridgets 2
T Lucas girling brake pads Triumph 2
davelgee Girling MK2a vacuum servos? Other Cars 31
Scott_Hower Girling Red Rubber Grease? MG 1
Adventurer_96 Girling Brake Question - UPDATE 2/12 Restoration & Tools 34
