Replacing veneer on wood dashboard
laneriddle
The veneer on my Tr6 dashboard is cracked. I think I can peel or sand it off of the plywood backing and replace it with new.
I have some woodworking experience.
My inclination is to clamp and glue the new veneer on the plywood and then cut out the holes for the instruments and what have you.
Does this sound right?
Administrator
Boss
Laneriddle, you have posted your question in the "forum help" section, which is really about asking questions related to the forum software (how to navigate the site, posting images, etc). I'm moving your post to the "Restoration and Tools" forum, which is a more relevant forum for your question. If you are reading this now, you are in that forum. I'll leave a "pointer" in the Forum Help forum that will direct people to your thread.
Bayless
If the dash is flat that would be a good way. If the instruments are recessed like a Jaguar then you can't. It is not easy to veneer a large piece like that either. You need another matching piece usually to apply even pressure as well as several clamps. Be careful if you sand to old veneer off so as to keep the surface perfectly flat too.
Popeye
Bronze
You sound like you are on the right track. If you search for "veneer" in the triumph forum, you'll probably get some good detail.
I did my TR4A dash a few years back, results are great. I used a bunch of weights and boards to distribute the load; if I had to do it again I would use vacuum (14.7 pounds on every square inch of veneer... great clamp!). I veneered both sides; one, so I could use the back as practice, and second, to keep the plywood symmetrical with respect to any warping over time.
Make sure the finish is UV-proof and can take some water. I used two products. The first was a mix of oil and urethane, Arm-R-Seal, and it gave me awesome visuals - strong grain and incredible depth. I followed this up with several coats of spar varnish for UV-protection. Both finishes were "gloss", and I wet sanded and polished for a nice flat look. (The last step took a few iterations, as I unfortunately sanded through the finish at the edges... argh!)
It takes time, the end-result is wonderful.
L
laneriddle
Thanks for info..lm wondering if a solid piece of wood (walnut or maple or something might be easier to manage? Is possible future warping the reason ply is used?
L
laneriddle
Thanks for your info,much appreciated.
would using a solid piece of wood be an alternative? Is possible warping a reason plywood is used instead of a solid piece of nice wood?
Popeye
Bronze
I'll let the wood-working experts chime in, however I would expect plywood to be much more stable from a warping perspective. Also, using a veneer allows you to have a more attractive piece of wood. I'm not sure you can get burled wood in "board" dimensions.
If you replace the underlying plywood, I would suggest to use marine grade plywood. The adhesive is water-resistant, and it has fewer internal voids than home-grade plywood. (This might be overkill - but given the time spent on the project, spending an extra $20-40 for good wood is insurance.)
Gliderman8
When I re-veneered my TR6 dash I built a β€œpress”
I placed the dash between two pieces of plywood and used LOTS of carriage bolts, washers and nuts. Applied the glue the placed the dash between the two pieces of plywood and systematically began tightening all the nuts so that the veneer was under a lot of pressure. Bolts went through the center of the gauge holes and around the perimeter. It worked great.
Grantura_MKI
You will find that modern veneers do not require all the clamping, etc. The material will have the adhesive already applied and is a peal and stick application.
Bayless
I wouldn't call adhesive back veneer particularly modern as it has been around for a long time. I have a couple of rolls of rosewood that I have been saving for a project since the 1960s. But regular veneer is still the most "accepted standard". Someday I may yet build that project. Looks like I need some of those round tuits that someone posted recently.
Grantura_MKI
I meant to say that the adhesive back material has come along way. Your 60 some odd year veneer is older than me and wouldn’t trust the backing anymore.
What do I know, just did a 34 Roller facia.
Bayless
Yes I figure the adhesive is probably gone on my veneer but the stuff is so pretty I would try regular glue on it.
Popeye
Bronze
Re self-sticking veneer. IMHO, it is a matter of "what would the cost of failure be". If I spent hours polishing, sanding, waxing my perfectly finished dashboard - only to have the veneer adhesive fail a few years down the road, I'd be madder than an angry hornet.
Automotive interiors are harsh places; hot in the summer, cold in the winter, exposed to occasional rain, vibration, etc.
My suggestion is to use a good wood glue, a water- and UV-proof top coat.
Again, my opinion.
NutmegCT
As a *very late* follow up, does anyone know what type of glue was originally used when the veneer was applied on a late '60s, early '70s TR6?
Thanks.
Tom M.
Gliderman8
When I re-veneered my TR6 walnut dash about 20 years ago I used powered pre-catalyzed resin. It has held up perfectly.... no de-lamination what-so-ever. After applying, I used a press that I made to keep the veneer under pressure for 24 hours.
This is what I used...
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
Joe Reed MGB Replacing heater cables... MG 29
