Uprated or 'umbrella' valve stem oil seals for BN1
CharlesBN1
Hello all. Where can I source uprated/"umbrella" valve stem seals in the US? Moss has them, but shows them only for late BN4-BJ8s, so I assume BN4-BJ8s valve guides and seals are different specs from a BN1/BN2. Moss has the O-ring valve stem seals, but I'd rather not use them. Thanks!
Healey Nut
I had great success on my BJ8s with a high temperature Viton O ring for my valve seals .
I just took a new sample O ring from the head gasket kit to a hydraulic supply shop and they matched it with the high temp version (they were much harder and a light brown colour)
No oil burning on either of my cars .
CharlesBN1
CharlesBN1
Thanks HN. I went ahead and ordered the BN1/BN2 valve seals from Moss. It's not burning any oil; I've got a sticking exhaust valve and I managed to cut the exhaust valve seal when I removed and reinstalled the spring set/retainer assembly. Incidentally, the machine shop that rebuilt the head used bronze valve guides (which is fine), but they failed to sufficiently ream one of the exhaust guides, so now I've got a sticking exhaust valve. What a pain..
T TR2/3/3A Moss uprated water pump Triumph 6
K TR2/3/3A Yellow wire uprated condensor Triumph 1
A TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems. Triumph 7
steveg Reflectors to Taillights - uprated Austin Healey 9
hondo402000 New uprated spindles and Wildwood calipers Triumph 11
nissanite TR4/4A Uprated TR-4 oil pump or.... Triumph 13
RedTR3 TR2/3/3A TR3 Uprated Water Pump? Triumph 11
C Uprated springs or stock? Triumph 2
Westfield_XI Uprated axles for wire wheel hubs/Frontline Spridg Spridgets 6
G Has anyone uprated the rear axles to CV joints? Triumph 47
SCguy Uprated differential bushings??? Triumph 4
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
