Toyota 5-speed shifter bushing
Michael Oritt
I have a Smitty's five-speed conversion in my 100 which has about 60K miles on it. I believe, but am not certain it is the W58 version.
It has recently become difficult to engage any gear (1 to 5 and R) from neutral. The clutch is engaging/disengaging properly and the transmission is full of Redline MT90. The amount of effort to get into any of the gears does not change at speed, whether the car is hot or cold or whether or not I double-clutch.
I am suspecting/hoping there is a bushing at the base of the shift lever that has become worn and in fact a dose of WD40 into the top of the tower made shifting a bit easier.
I don't want to show up at the Toyota parts counter only to be turned away for lack of a part number and am hoping someone might have it.
TIA....
roscoe
I just finished doing the Delaney (Smitty)5 speed conversion but my shift lever came with the part in question installed. Perhaps Pete Delaney can help you out. A quick Google search gave me this which I'd bet is what you need. PART NUMBER 3354831010
Patrick67BJ8
Besides the shifter part wearing out, could the fulcrum pivot stud have worn down?
CraigC
I posted this on AHExp as well..............
Michael, didn't you replace the shifter seat and the nylon socket late in 2018? Have you pulled the shifter out to confirm the problem? Typically these failures result in a sloppy shifter as well as difficulty in fully engaging the gears.
Dorman kit #924-258 contains both parts.
Toyota #33505-35020 for the "seat"
Toyota #33548-31010 for the "bushing"
For a heavy duty upgrade try "Marlin Crawlers", a 4wd supplier. They have a delrin seat.
....... http://www.marlincrawler.com/shifter-parts/new-heavy-duty-seat-socket-combo I would probably call them to confirm it fits all W-series shifters.
Michael Oritt
Michael Oritt
All--
I must apologize for the seeming lack of etiquette on my part in not having posted some resolution, update, etc. to my original query about the bushing p/n and the underlying problem of difficult shifting, etc. Several of you responded on 10/25 with the number and I ordered it from the local Toyota dealer next day, but on 10/27 I had my right knee replaced and really didn't feel much like doing anything beyond rehab for a couple of weeks. Last Friday the surgeon cleared me for driving and today I thought it would be good to see if the new bushing would do the trick.
I gave the 1/4-turn spring-loaded ring a twist and removed the shifter, hoping to find a severely worn bushing but I really could not see much difference between the old one and its potential replacement. Nevertheless I knocked the old one off and snapped on the new bushing but before closing things up I added about 2/3 quart of MT 90. After reassembly I started the engine and rather easily engaged reverse, then backed out the driveway. All seemed good so I took a 15-20 mile ride going up and down through the gears, and everything seems just fine. It is possible that I under-filled the Toyota box when I last changed the oil and the bit I added today solved the problem but if that were the case I probably would have noticed the difficulty in shifting right away, which was not the case. If the box is now overfilled no oil was coming out of either the vent or shifter today as there is not a puddle under the car.
For now I am willing to take yes for an answer to the cosmic question of "what just happened?" but in any case it certainly did feel great to be driving the car once again.
roscoe
This thread would have been more amusing if it had been your left knee you needed done. A bum knee would certainly make shifting difficult. I think one of the big Healey suppliers is having a Black Friday sale on left knee joints. I think they are listed under "body parts." Next to new (steering) knuckles they are a big seller. They are also selling various sorts of elbows and even new heads. I actually replaced my head with an aftermarket one made by The Lunker Company, Ltd. So now I guess I'm a lunkhead.
You've all been great, I'll be here all week.
M Toyota 5 speed Shifter Austin Healey 2
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
Michael Oritt Toyota 5-speed Problem Austin Healey 28
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
M synthetic fluid in a toyota 5 speed? Triumph 20
prb51 Tr Toyota 5 speed upgrade Triumph 24
Bob McElwee Toyota 5 Speed Conversion Questions Austin Healey 10
gsalt57tr3 TR2/3/3A 5 speed Toyota transmissions in a TR3 Triumph 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR6 Toyota Transmission conversion Triumph 8
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
aeronca65t One less Toyota 2000 GT Other Cars 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
4 Another Toyota Twink Spridgets 13
tinman58 Toyota trans noise Triumph 9
PatGalvin TR2/3/3A Toyota Brake Conversion on a TR3A Triumph 5
PatGalvin Routing brake lines for Toyota 4 pot conversion Triumph 5
T TR4/4A Toyota calipers for a TR4A Triumph 18
T GT6 Toyota caliper swap for GT6 like TR6? Triumph 3
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
R 1989 toyota camry, rough idle when in gear, help Other Cars 6
prb51 Toyota tranny users-Speedo Triumph 15
