BN6: How to case spikes of the screws of the door panels
BN6_2197
Gents,
how can I case the spikes of the lower screws of the door panels (see attached picture)? Whenever I put things into the door bags my fingers get injured by the spikes. Is it expected that the spikes of the screws have no covering?
Regards,
Volker
Madflyer
Two ways well three ways Big box HW store have caps that would cover points. Add a padded foam bottom above points. Or the best way to not hit your thumb with a hammer is do not use a hammer. Madflyer
Healey Nut
Once the screws have done their job of screwing into wherever they are going for the first time, they have done their job of cutting the thread. Remove them, grind, cut, file the point off and put them back in. Job done.
nevets
This thread got me curious so I took a look at my BN6 door and took a few pics. The screw points are located below the 'floor' of the door compartment, so there is no chance for a hand coming in contact with them. Hope this helps.
BN6_2197
BN6_2197
What do you mean by "floor of the door compartment"? There is nothing else than the pure metal of the door inside my door comparment.
nevets
"What do you mean by "floor of the door compartment"? There is nothing else than the pure metal of the door inside my door compartment."
The door compartments in my BN6 seem to have a bottom panel, which is visible if you look carefully at two of the photos that I posted. However, I took another look (and feel) and discovered that the screw tips do indeed protrude into the compartment. I just never noticed them, probably because I have rags and other stuff stored in the driver's side door compartment. Apologies for the confusion.
John Turney
The hard-backed vinyl panel that covers the inside of the outer door skin on mine has a narrow panel that folds up to cover the bottom. I got the interior panels from Moss ~30 years ago.
Dandare
You may have some of those plastic rawl plug type things hanging around at home that you could screw on from behind?
Danny
BN6_2197
BN6_2197
You are right, it covers the bottom, but the bottom only. The screw pikes are above this cover in my car. Are the pikes beneath that bottom-cover in ypur car?
John Turney
They are above the bottom cover. If I had thought of it when I installed it, I might have raised the panel so the bottom could have sat on the screws. I didn't.
BN6_2197
BN6_2197
Zoomed into your picture and saw some kind fitting in the inner side of the door (see arrow of the attachment). This is missing from my car. Is it a common spare part?
nevets
"Zoomed into your picture and saw some kind fitting in the inner side of the door (see arrow of the attachment). This is missing from my car. Is it a common spare part?"
I don't know if it's stock or a mod. I did not do the restoration. Perhaps others will know. I can check my BN6 parts catalog.
John Turney
That's a reinforcement piece for the door opening. I have one on my right door but not the left one. I'm sure my left door isn't original (the door doesn't have the bump under the Longbridge lock), but I don't know if the right one is or not.
I have never seen one as a separate piece.
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
nevets BN6 horn button Austin Healey 17
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
maxwedge5281 bn6/7 hardtop Austin Healey 18
maxwedge5281 changeover to negative ground in my bn6 Austin Healey 9
