TR2/3/3A center panel indicator light color
deuce
Hi Folks.. I have a later tr3a.. 78xxx. 1960. My question.. The indicator lights on my car were red and green. I have no reason not to believe they are original. Any photos I have seen the lights are red and amber. Oh, the question.. Is mine correct or was there just a substitution for convenience on the production line? Not a big deal I guess but I wouldn't want anyone looking and saying ugh, you have a green indicator light:friendly_wink:
charleyf
Your dash is correct for a later TR3. I do not know when the change occurred. But the later is red and green. And that continued into the TR4.
Frank Canale
My car is 1960 # TS61324, took a look at my panel and my dash lights are RED and AMBER. Maybe this will help with determining where the change over took place. Frank
ckeithjordan
According to Piggott, the change occurred in March, 1960 at TS70182.
ckeithjordan
Just to clarify my remarks, prior to TS70182, the turn signal dash indicator was amber, after that, green.
ckeithjordan
As has been discussed before, there are “official” changeovers (mostly based on Service Bulletins, etc.), then “unofficial” changeovers (mostly based on various parts being available or not, using up old stocks, etc.). I’m not surprised that your experience is different. Odd? Probably not.
Tr3aguy
Well alrighty then... not like I am going for a concourse restoration anyway so...
6TTR3A
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
L Light for BJ8 Center Dash Panel Austin Healey 17
A TR-3A wooden center dash panel photo??? Triumph 3
S TR4/4A polished center panel for 62 TR4 Triumph 3
60Bugeye New Center Rear Panel or Repair? Spridgets 20
timsgolf Center Dash Switch Plate Painting Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
D 62 center shift gearbox Austin Healey 11
R Center Gearbox Input shaft bearing Austin Healey 9
D 1962 center shift gearbox cover Austin Healey 7
AUSMHLY Distributor cap center pin melted Austin Healey 5
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
charleyf TR2/3/3A Center main cap engine Triumph 4
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
P Turning to Top Dead Center Austin Healey 11
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
