Temperature sender
I recently purchased a radiator for my Longbridge built BN4. It does not have the opening or fitting for the temperature sender. What are my options other than the two obvious ones, sending it back or going without....
John Turney
Do you still have the gallery head? If so, changing to the later head is a third option.
Installing a tap into the thermostat housing might be a fourth option.
Installing a fitting into the upper radiator hose would be a fifth option. I have a temperature switch in my upper hose for the electric fan. Available from Amazon, but you would probably have to retap for the bulb threads.
I don't recommend going without.
longbridgehealey
I do have the gallery head. I’ll take a look at that possibility. Thanks, John
longbridgehealey
John, take a look at this...
red57
I suggest returning it and have your original one re-cored. Unless it was in an accident, the tanks are usually re-useable (and will have the correct original tags and temp gauge bung in the right location) and the modern core will be more efficient. This is very common work for most radiator shops.
Dave
longbridgehealey
Lesser of the evils I think. The frame of the original is bent quite a bit, probably past recoring.
steveg
LBH - the fittings as John describes above are available in several different hose sizes and temp sender pipe thread sizes. If you decide to go that route, you'll probably be able to get what you want with careful shopping.
longbridgehealey
Thanks, Steve. You’re right, I’m already finding a variety of them. Tomorrow I’ll have to figure out the pipe thread size.
John Turney
I doubt the threads on the temperature bulb are tapered pipe threads. If you haven't recycled the old radiator, maybe you can unsolder the temperature bulb fitting from it and solder it onto a short brass nipple that can be threaded into the new hose fitting.
steveg
Agree with John, tapered threads wouldn't work with how the tube nut seats against the bulb.
I wasn't able to measure mine, but based on the 5/8" wrench size, would guess it's a 1/4" BSPP thread, dimensions: .51" outside diameter, 19 tpi pitch.
EDIT: the adapter shown blow would have to incorporate a beveled seat for the bulb to seal against. It might have to have an insert.
If the bolt centers equaled those of the Healey, a riser would be an easy solution used with an NPT male to BSPP female adapter:
Madflyer
Best fix I have seen in a long time - good call. One to remember, thanks. Madflyer
longbridgehealey
Danny, no tapping.
longbridgehealey
Steve, absolutely great solution, thanks yet again!
Larry
red57
Along the lines of John's suggestion (post #10 above) - unsolder the bung from the old radiator and take it, along with the new radiator, to a radiator shop and have them drill a hole and install the bung in the stock location and then you don't need any of these adaptors - everything remains stock.
Dave
longbridgehealey
Well, all were absolutely great and doable solutions, thanks everybody. Ended up using Dave’s solution and having a radiator shop remove and install the bung in the new radiator. Everything’s back in place and on the road again. Just in the nick of time, because my wife just bought a pallet of flagstones and a yard of sand for me to build her a garden path. I see the garage time dwindling to a wee bit in the near future!’
Thanks again!
Larry
steveg
Just by coincidence after 2 weeks of Thermocure in the system, today my TR6's radiator sprung a leak. Later TR6s didn't come with a drain tap.
Local LBC-friendly radiator shop is installing a 1/4" NPT bung for the drain tap, and a 1/8" NPT bung for my electric fan thermo switch. He had these (brass) bungs in stock.
longbridgehealey
Thank goodness there are still local radiator shops.
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
T TR2/3/3A Can you drive TR3 w/ temperature sender removed? Triumph 13
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
L Temperature sensor relocation in BE with A 1275 Spridgets 8
