TR6 Headlight switch - can it be rebuilt?
steveg
My headlight rocker switch works intermittently in the fully-on position. They're backordered at the Usual Suspects.
Is it possible to take the switch apart and rebuild or rejuvenate it?
For the Lucas switch, how much enlargement of the opening is required?
TRopic6
Hi Steve, I did the repair on the switch shown on the Experience Forum. It's not in a car but I've cycled it about 100 times and it seems OK. The metal contact affair the ball rolls over is pretty touchy and hard to fix if it gets bent or out of alignment. Take the halves apart carefully by drilling out the glue in the 6 depressions and carefully separating. Watch out for the spring and steel BB that are probably loose in the bottom. I put the headlights on a relay so the 8 or so amps wouldn't have to pass through the switch. Jeff
sp53
Many moons ago in my wife’s triumph (forgot all about it) I used an electrical roll switch for ac current to get I think 3 poles on at the same time. It looked really Mickey Mouse, but worked well (this was probably 1975) and the stock factory replacement switches had been recalled or something then many years later got one in the mail from triumph.
B Headlight Dip Switch Austin Healey 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Upland 3 position headlight switch is now 2 Spridgets 1
S TR4/4A Headlight switch wiring. Please help Triumph 2
S Replacement Headlight Switch Spridgets 4
Z TR6 74 TR6 - Changing headlight beam switch issue Triumph 0
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
R TR4/4A headlight switch TR4a Triumph 34
Newkie T-Series Turn signal headlight dimmer switch question? MG 2
HAN8L1965 Headlight Dash Switch mkIII Spridgets 4
AUSMHLY Headlight switch - fried Austin Healey 23
wkilleffer T-Series Problem with the headlight dip switch MG 1
Newkie T-Series Headlight Dimmer Switch help MG 0
A T-Series MG Headlight switch MG 6
R T-Series Wiring harness - headlight switch MG 3
Bob McElwee Dash Park/Headlight Switch Austin Healey 6
J T-Series Electrical Problem: headlight switch turns starter MG 28
S New Headlight Switch but no Lights Triumph 21
2wrench TR6 What holds this TR6 headlight switch in place? Triumph 12
MGTF1250Dave T-Series MGB Headlight Switch Gets Very Hot MG 15
wkilleffer T-Series Rant about turn signal and headlight switch MG 37
D Headlight Switch Spridgets 9
J hot headlight switch! Triumph 6
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
Spock TR6 '72 Headlight Relays Triumph 4
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
