TR6 Recommendation for tail lamp to body gasket
nichola
Bronze
Can anyone recommend a decent gasket for sealing the tail lamp assembly to the body for a TR6? The one I received is a terrible fit (see pics), requiring a LOT of stretching to get it anywhere near where it needs to be. Alternatively, has anyone tried making their own, perhaps using a round foam cord? Thanks for any advice.
While on the subject of rear tail lamps... the replacement bulb holders are also worthless. Better off trying to rescue the originals.
mrv8q
Back in the day I used TRF gaskets and thought they were fine. A little plastic polish, some silver paint for the reflectors and the taillights looked spiffy again.
nichola
nichola
Bronze
Try a contact cement for seal I think it needs to be that thick as never a good fit to body. Madflyer
Yep, I agree it has to be thick like that, but it's too short and too narrow. I would have to stretch it in both directions and glue it to make it work.
nichola
nichola
Bronze
These are from TRF. I have refinished lamp assemblies, too, including "chrome" paint on some of the reflectors. I'm getting some foam rope and also a foam sheet today to see if I can make something that fits better, from McMaster-Carr.
Popeye
Bronze
Have you tried pressing the assembly into the sheet metal on the car? Gaskets are a tricky beast; sometimes they look all wrong but work, sometimes they shrink before installation due to being old, and sometimes they just aren’t made right!
Madflyer
If you find some foam or rubber to cut to fit be aware it does not hold water as may cause rust. I was looking at my PC mouse pad not big enough but a good rubber to look for. places that sell fan belts also sell all rubber sheets Industrial supply Madflyer
nichola
nichola
Bronze
I ordered closed cell foam that's good for all weather usage according to the website.
nichola
nichola
Bronze
The assembly itself fits pretty nicely with just a little bigger gap right at the corner. But the new replacement 3/8 thick gasket seems to have shrunk like the waistband on my trousers. See the attached photos... gasket almost an inch shorter across the rear facing part than the fixture.
sp53
I find the foam tricky to cut. What I have been using to cut foam is a pair of those 10 inch or so long blade scissors. Then, I get the scissors square for a straight long clean stroke so as they close they do not leave those jagged marks----for me this seems to work best. It looks like the gasket is 2 pieces glued plus foam is often inexpensive enough to practice on like an artist.
steve
Madflyer
Cutting foam; a razor knife can work A old knife laid on marked lines and hit with a hammer to shear foam also for corners a old socket say 1/2 hit with a hammer all will make a clean cut and round. I do gaskets this way for bolt holes. Madflyer
nichola
nichola
Bronze
Thanks for the ideas. I’ve cut one from a flat 3/8 sheet but have yet to tackle the round outside corners. I’m also thinking the 3/8 foam cord would be much easier to deal with if i can find a contact cement that will hold it in the channel while I attach the assembly to the body. That’s what I’m trying tomorrow.
Madflyer
What if foam covered more and just edge had holes for lamps and screws rounded with a simple trim and not so round. easy glue and large size of water pipe to cut holes stamped with hammer. Madflyer
steveg
Smaller holes - I've had success with a short sharpened piece of 3/8" tubing in my drill. For carpet snaps, I use a sharpened piece of EMT conduit tubing which I hit with my knockoff hammer.
nichola
nichola
Bronze
All done, could not have been easier using the 3/8 diameter EPDM foam rope. Ten feet from McMaster-Carr for $6, plus a ten pack of super glue from HF for $3.75. Each lamp assembly took a few minutes to glue down the rope in one continuous piece. To be safe I taped the corners down with masking tape until just before I installed onto the body. I laid a bead of glue down in the channel and spread it a up the sides of the channel with a small brush. The glue sets in a few seconds. This is the same type of foam used in automotive door seals, I think. Super glue is the best adhesive to use, in the gel form. Clean up with acetone.
I used a piece of the 3/8 sheet foam to bridge across the middle of the rear part of the fixture like the stock gasket and added a little length of foam under the cord at the front edge of the side marker to push it out more toward the edge because the channel gets much wider there. Might even consider using the 1/2 inch foam if I had to do it again. Can't remember if they sold a 7/16 diameter cord.
J T-Series Mechanic recommendation MG 0
J Request for soldering iron recommendation Restoration & Tools 6
B TR6 Help with color and color code / paint recommendation Triumph 4
T TR4/4A Recommendation on top for a late TR4A Triumph 8
B Recommendation on wheels Austin Healey 19
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
S TR2/3/3A Front coil spring recommendation? Triumph 7
JimTR4 TR4/4A Battery recommendation Triumph 11
S Grease Gun Recommendation? Spridgets 7
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
maxwedge5281 auto transport recommendation Austin Healey 10
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
R Seeking Upholster Recommendation Austin Healey 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C Recommendation for Healey mechanic in Naples/Ft. Myers Florida area? Austin Healey 11
S Rust treatment recommendation? Austin Healey 5
P Good fitting car cover recommendation? Austin Healey 9
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
I Bigeye fuel filter and placement recommendation? Spridgets 8
T TR2/3/3A Camshaft Recommendation Triumph 13
tmcarthur Tool Recommendation Spridgets 7
PAUL161 T-Series New Firestone Tires Recommendation MG 2
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
B Replacement Interior Recommendation Austin Healey 11
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
J Restorer recommendation Austin Healey 33
L TR4/4A Surrey Top repair recommendation Triumph 2
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M Pebble Beach/ Monterey Good Accommodations Recommendation Austin Healey 13
S Texas restoration recommendation? Austin Healey 2
B Interior Recommendation Austin Healey 8
H Carb rebuilder recommendation? Triumph 5
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
L PPI recommendation, Jacksonville? Austin Healey 2
B Battery recommendation besides Optima Austin Healey 17
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
boeingpilot Shop recommendation Ft. Worth, TX Triumph 11
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
D Steering Wheel Recommendation MG 4
G SU book recommendation needed Spridgets 7
Michael Oritt Need muffler recommendation Austin Healey 16
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
T Thermostat ugliness & temp range recommendation Spridgets 13
T Sway bar recommendation for a Bugeye Spridgets 21
