MGB 73 sat for 6 months
jsomersdc10
When I start the car now i get a rough idle. Have to leave choke about half way out and idle at about 1000 RPM to keep it running. Put new plugs in with old plugs in 1 and 2 looking black. I have spark to all the plugs. At idle, I pulled spark plug wires one at a time. idle slowed on 3 and 4 but no change when 1 or 2 pulled. Engine runs real rough if any gas added. I added some gas heat fluid to remove any possible water in fuel line. Actually took a sample of the gas prior to the carbs but did not see any water. Any ideas?
Thanks,
Somertime
JPSmit
is it old gas? and especially regular gas? this is quite typical of cars that have been sitting and a fresh tank usually solves it. ethanol can gum things up as well.
Platinum
Ethanol gas will mess up carb passages in as little as a couple months, depending on humidity. Front carb has likely been gummed up. Both need to be gone through thoroughly. And use a gas stabilizer if the car is going to be static for any length of time.
JPSmit
FWIW I was given this by my mechanic a couple years ago - transformed the car.
Seafoam might work also though I have never used it
Madflyer
Seafoam works great in 15 min of running. Todays gas is terrible sitting is terrible some say park with full tank only or empty gas additive always. change filter or clean. There a lot of post where guys park a car for years and think it will just start and drive away. Not in todays world. Moist air temp changes summer winter. In Reno Nevada I open a vent to garage car stays above 50 Deg. year round. Madflyer
J
jsomersdc10
Thanks for the info. Using a gas stabilizer and know I need to drive it more. I think the front carb is probably gummed up. Will check out the Mopar and Seafoam.
LarryK
Heat is alcohol just adds more water especially in ethanol induced fuel. Methonal bad for rub er. Worked in winter to spark the alcohol and melt water.
pdplot
My cars are laid up almost 4 months every winter. I throw in some fuel stabilizer in January and sometimes some Drygas. Cars have never failed to start and run fine when started in May.
LarryK
I started using the Marine stabilizer, as I use it in the boat. It is better on the ethanol as outboards don't tolerate as well.
J
jsomersdc10
Hey guys, thanks for the help. Cleaned out the front carb and for good luck tapped the float bowl several times. She started right up, running smooth. Probably going use Seafoam as my gas additive. Thanks agin and stay safe.
Somertime
jlaird Just may be the new Miss. Agatha. Sat will tell, only 37 miles away. Spridgets 26
B Jags N Java, Sat. Sept. 20th, Wallingford, CT Jaguar 0
DerekJ I've just sat in NOJ 393!!! Austin Healey 12
jlaird Sat Morning Spridgets 10
V Shenandoah Valley Brit Car Club show Sat. Oct. 2 Triumph 12
jlaird Engine arrived Sat. Spridgets 10
amcboy Idiot test sat... Triumph 10
jlaird Spent last sat nite Spridgets 7
kcbugeye1275 Great Sat. Spridgets 0
Brosky Cape Cod show either Sat or Sun [rain date] Triumph 2
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
H Ran in my first road rally Sat. Other Cars 15
jlaird Progress-Sat Spridgets 9
jlaird Sat morning fuel leak test Spridgets 3
YankeeTR Spitfire OK...Who was towing their Spit in Indiana on Sat ? Triumph 0
jlaird Well it is Sat. Spridgets 7
tr7andtvr Anyone going to the Chattanooga show this Sat. Other British Cars 3
H Pic from Sat Austin Healey 3
H Sat. 4/1 TVR pic Other British Cars 7
S Starting up cars that have sat for a long time. Triumph 20
D GT6 9 months later. GT6+ progress Triumph 3
Jim_Gruber And Bugsy Spoke for the first time in 18 Months tonight Spridgets 15
V Last few months in the UK Pictures TVR 5
DrEntropy Off Topic Been a busy few months... MG 7
vickxxx TR2/3/3A new water pump noisy after 6 months Triumph 5
T TR2/3/3A Petronix Flame thrower coiled failed after 1-1/2 months Triumph 8
A 1963 BJ7 - 6 months of hard work Austin Healey 12
T restarting after six months Triumph 2
britndablood HD6 jet diaphragm only lasted 8 months Austin Healey 7
Darrell_Walker Wedge TR8 - 3 months in Triumph 14
livinginthepast Signing off for a couple months... Spridgets 7
Brosky Seven months of hibernation over..... Triumph 19
RickB T-Series Looking for brake light switch to last >6 months?? MG 14
vping After 11 years and 4 months... MG 12
F TR6 Help..TR6 won't start after months of sitting Triumph 33
kbash My first drive in 8 months MG 8
MadRiver Starting the car after two months Triumph 3
G Three months of toil Triumph 24
S Wedge Drove the TR7 for the first time in 8 months! Triumph 7
J Jaguar XKE restoration story in this months new R&T Jaguar 3
