Results 1 to 8 of 8
Thread: Under dash fuse
  1. #1
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,121
    Thanks Thanks Given
    1
    Thanks Thanks Received
    14
    Thanked in
    Under dash fuse
    I believe that I have seen pictures of the back of the TR3 dash panel showing an in line fuse. But I can not find any wiring charts showing that. Can anybody verify the presence of a fuse and on what wire it is on?
    Charley
    1962 TR4
    1963 TR4
    1959 TR3A A work in progress.
  2. #2
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    3,624
    Thanks Thanks Given
    17
    79
    Thanked in
    Re: Under dash fuse
    Hello Charley
    Here is a copy of a diagram I believe Randall put up. It is Item 41 on this drawing feeding the light switch.
    David
    TR3A TS75524L
  3. #3
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    343
    Thanks Thanks Given
    3
    10
    Thanked in
    Re: Under dash fuse
    This photo shows the fuse and I think it is for the park lights.
    Graham
    [SIGPIC][/SIGPIC]
  4. #4
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,620
    Thanks Thanks Given
    39
    Thanked in
    Re: Under dash fuse
    hi Charly, I could not find the picture of the fuse, but when I get under the dash again I will take a picture. The fuse started about 1959 and is in a metal canister; the fuse is in the red tail light wire and has a moveable clip on the canister that clips right in the center of the gauge panel at the bottom. The clip the fuse hangs on looks like one of dash covering clips plus when in place functions as one with those little barbs. plus very rare to find.
    steve
  5. #5
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,121
    Thanks Thanks Given
    1
    14
    Thanked in
    Re: Under dash fuse
    Thanks to all. And a belated thanks to Randall for putting together his wiring chart. I have 4 copies in 4 books of the wiring chart and none of them showed the fuse. Looking at pictures I got lost following the wires. So the fuse goes on the power feed from the light switch to the panel light switch. I would have guessed that it would have been on the brown/ blue power input wire to the light switch. But that would have put a fuse in line before the headlights.
    Thanks David for coming up with the chart. I appreciate the help from all of you.
    Charley
    1962 TR4
    1963 TR4
  6. #6
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,620
    Thanks Thanks Given
    39
    Thanked in
    Re: Under dash fuse
    A tr2 wiper motor wires different than tr3 wiper and I think you said you have tr3 engine, so I was suggesting maybe other components might be later. If you look at the wiring diagram, the gauges are labeled incorrect; it has the gas gauge and temp gauge mislabeled. You friends probably know that, but in my experience not many people know the little things about a tr2. Here you have John and Long door and they experience
  7. #7
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,620
    Thanks Thanks Given
    39
    Thanked in
    Re: Under dash fuse
    Sorry Charley I posted in the wrong thread
  8. #8
    Join Date
    Apr 2013
    Location
    redding,ca
    Posts
    1,121
    Thanks Thanks Given
    1
    14
    Thanked in
    Re: Under dash fuse
    After getting the information, I went out and found an original fuse with red/green wire to fuse to red wire on an old TR4 wiring harness. I also found the clip that the fuse holder goes in.
    Again thanks to all for the help.
    This project came as a true basket case with a body sitting ( no bolts) on the frame and with numerous boxes loaded with parts sitting in the car. It continues to be a fun challenge to get it back together.
    Charley
    1962 TR4
    1963 TR4
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
