TR2/3/3A Under dash fuse
charleyf
I believe that I have seen pictures of the back of the TR3 dash panel showing an in line fuse. But I can not find any wiring charts showing that. Can anybody verify the presence of a fuse and on what wire it is on?
DavidApp
Hello Charley
Here is a copy of a diagram I believe Randall put up. It is Item 41 on this drawing feeding the light switch.
David
sp53
hi Charly, I could not find the picture of the fuse, but when I get under the dash again I will take a picture. The fuse started about 1959 and is in a metal canister; the fuse is in the red tail light wire and has a moveable clip on the canister that clips right in the center of the gauge panel at the bottom. The clip the fuse hangs on looks like one of dash covering clips plus when in place functions as one with those little barbs. plus very rare to find.
steve
charleyf
charleyf
Thanks to all. And a belated thanks to Randall for putting together his wiring chart. I have 4 copies in 4 books of the wiring chart and none of them showed the fuse. Looking at pictures I got lost following the wires. So the fuse goes on the power feed from the light switch to the panel light switch. I would have guessed that it would have been on the brown/ blue power input wire to the light switch. But that would have put a fuse in line before the headlights.
Thanks David for coming up with the chart. I appreciate the help from all of you.
sp53
A tr2 wiper motor wires different than tr3 wiper and I think you said you have tr3 engine, so I was suggesting maybe other components might be later. If you look at the wiring diagram, the gauges are labeled incorrect; it has the gas gauge and temp gauge mislabeled. You friends probably know that, but in my experience not many people know the little things about a tr2. Here you have John and Long door and they experience
charleyf
charleyf
After getting the information, I went out and found an original fuse with red/green wire to fuse to red wire on an old TR4 wiring harness. I also found the clip that the fuse holder goes in.
Again thanks to all for the help.
This project came as a true basket case with a body sitting ( no bolts) on the frame and with numerous boxes loaded with parts sitting in the car. It continues to be a fun challenge to get it back together.
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
G TR4/4A Under Dash Pics Triumph 2
M TR2/3/3A The Sequel: Water from Under the Dash Triumph 3
PatGalvin TR2/3/3A Assembly Sequence, Dash and Under Dash Triumph 10
KVH TR4/4A Burned Wires Under the Dash Triumph 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
longbridgehealey Under dash grounds for BN4 Austin Healey 11
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
F Wire insulation damage under the dash - Bugeye Spridgets 5
Tugboat TR2/3/3A Pictures Under TR3A Dash Triumph 20
ekamm TR2/3/3A under dash acess tr3a Triumph 11
ekamm random leather under dash cap Triumph 5
tinman58 TR2/3/3A Wood pieces under dash of TR3 Triumph 12
R Under dash wiring problem-BJ7 Austin Healey 10
K Under Dash Wiring Triumph 4
CraigLandrum Wood under from dash capping? Triumph 11
ronzet Choke cable mounting under dash BN4 Austin Healey 5
tony barnhill Under Dash Liners MG 3
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
SCguy TR4/4A TR4 Under the Dash Vent Question Triumph 6
F DIfferent heaters---under dash or front of battery Spridgets 11
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
MadRiver Under dash "kidney" panels Triumph 10
L Smoke under the dash MG 4
M under dash panel MG 2
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
J TR2/3/3A Pads under new floor Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
B Under bonnet fuel Austin Healey 15
D MGB Stopping rust under patch panels MG 1
T Coroplast Signs under Wheels Austin Healey 0
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
C Under boot and under bonnet paint? Austin Healey 7
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
W Electrics, fuel system, under bonnet temp. Austin Healey 3
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D TR2/3/3A Under hood Photos Triumph 7
D Lilly under her own power... Austin Healey 7
