How do I clean sand out of a ring & pinion?
twas_brillig
In my other thread, trying to figure out why the power train locks up on our BE with a Datsun 5 speed, I mentioned pulling the pumpkin out of a spare axle assembly, and discovering that someone had drilled a small hole in the housing and then sand-blasted it, such that there's sand throughout the inside.
I'm okay with tossing the wheel bears if I should want to salvage those parts, but would sure appreciate any ideas as to how to clean all the sand out of the ring and pinion assembly, as I really don't want to disassemble/pay to have disassembled that finely machined and finely worn in assembly. Thanks, Doug
JPSmit
I suspect that the hole is actually a vent hole that didn't get blocked when media blasting. :madder: I have heard of people sloshing kerosene or some other solvent to clean things diffs but, from grease not sand. I think I would want to pull it apart and make sure it was properly clean. annoying though.
Joe Schlosser
If you are pulling the bearings then the main diff assy is coming out any way. so it can go into a parts washer after you remove the bearings. Remember to mark the shims. Moss sells different shims that are installed on the outside of the bearings.
The big issue is the pinion bearing. most likely requires a tear down.
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
BoyRacer How to clean a cloth wiring harness Austin Healey 14
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D TR2/3/3A Exhaust manifold clean up. Triumph 6
I General TR Mold clean up suggestions Triumph 4
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
R General TR Best way to clean unpainted parts Triumph 1
jaegzie Cylinder wall has some build up. Need to clean. Spridgets 4
NutmegCT Cooling system clean/flush Restoration & Tools 11
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
nevets How to clean a E Z Bleed ? Restoration & Tools 11
C How to clean a Lucas Headlight? Restoration & Tools 5
R did a little clean up today Triumph 5
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
Darrell_Walker Fuel tank - just clean, or clean and seal? Triumph 15
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
T silcone clean up Triumph 9
Moseso Mini ! Clean! Also, heavily customized ! Spotted 2
bighealeysource How to clean up rear backlight on factory hardtop Austin Healey 11
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
Rut Transmission clean up Restoration & Tools 5
W Garage clean up Spridgets 0
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
J Paint help! [I've got a mess to clean up] Triumph 9
D Wire wheel clean prior to paint MG 1
ekamm Clean looking sedan on Eastcoast Triumph 0
M What's the best way to clean off under-gunk? Spridgets 10
T best way to clean a canvass top? Triumph 4
T Working with clean parts is soooo very nice Triumph 19
SilentUnicorn How not to clean a motorcycle chain British Motorbikes 6
tmc Clean the gas tank or buy a new one? Triumph 8
J what should I use to clean 30yr old vinyl? Triumph 6
T Radius arm clean-up and bushings Spridgets 7
B Time to go racing again - seeking clean Spridget Racing 32
T 30 minutes of clean up and much better Triumph 19
T MGB-GT Clean MGBGT cheap on BMW forum MG 5
T How should I clean my diff now that it is out..... Triumph 9
P Clean behind the Grill on a 100 Austin Healey 3
jjbunn Calipers! How to clean and install? Triumph 7
boeingpilot Brake Rotor Clean Up Restoration & Tools 4
RickB To clean old tarnish off replacement fuse box? Spridgets 10
walshja how do you clean Spridgets 5
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
regularman The clean up Spridgets 0
