TR5/TR250 Trans slipping in reverse
tinman58
I have a recently rebuilt transmission. Works fine, except when in reverse I get a slipping (not clutch). The transmission guy said it sounded like the rear hubs. The diff was leaking gear oil so I pulled the axels and the diff out and took them to a shop to be checked and rebuilt if needed. I still don’t understand how slipping could be from the rear end. Tranny guy also said that 1st and reverse are on the same shaft so can’t be transmission. What am I missing?
CJD
I think they meant the rear wheel hubs rather than the differential. Do you have wires? The wire to wheel hubs can also slip.
tinman58
tinman58
I have both. I like the rostyle caps and my wife likes the wire wheels. It slips with both. I don’t understand how the hubs can spin.
Madflyer
Hub slipping ???? Splined hubs if it slipped one time that is one time to many. Question??? With rear on jacks and EM brake set can you turn either rear wheel you may be stopping on front wheels only (very bad idea ) These splines are very fine and ounce rolling you would not feel a slipping wheel. Starting in first and lower Rev. will slip as load is heaviest. This can happen with lack of service rust very hard driving. I would tell you to go on a empty road and hit brakes hard. most TR will not lock wheels but you may not stop very well. OK do not try this at home you need all new hubs and rims through in new tires too. I have only seen this happen on Jags that are much heavier cars. Madflyer
tinman58
tinman58
Mad flyer , it only slips in reverse and with the steel rims. Splices on the set of wire wheels are in great shape and pretty new.
philstr6
(Tranny guy also said that 1st and reverse are on the same shaft so can’t be transmission)
1st and second are on the same selector shaft,reverse is on its own selector shaft,
phil
Madflyer
I guess we do not under stand slipping do you mean it will not go backwards?? The bell crank to shift into REV may have been mist when cover replaced. Madflyer
titanic
The reason I asked if the trans. has OD is that the cone clutch in the OD transmits the power in reverse. If the inner linings on the clutch are worn or the clutch isn't functioning, it will slip in reverse.
Berry
CJD
Is it just a slip, or is it accompanied with a grinding or ratcheting sound? Also, OD or non-OD tranny?
tinman58
tinman58
I do have od. There is no grinding or other noise. It is just like maybe half the power is transmitted to the rear wheels. If backing up a steep driveway it seems worse. So could be overdrive. The rebuilder of the transmission was not a Triumph Guy. He said a transmission is a transmission. I should have had a Triumph mech do the rebuild!
CJD
Well, if you have ruled out the clutch...and there is no grinding, which would mark a bad gear, hub sprocket or wheel sprocket.
Then I am afraid the OD is next. You very well may be stuck in OD, and you can damage the OD sprag clutch trying to go in reverse. There is no reverse in OD, so the sprag clutch attempts to prevent reverse movement of the car. If forced, it will shatter the sprag. Most who have tried to reverse with the OD stuck describe reverse as "hitting a curb" feel. If you are lucky, your sprag is slipping, rather than locking and shattering.
I used straight non- detergent 30w in my OD, as the book recommends when I rebuilt it. The OD would stick engaged until I took a wrench and wacked the OD bell a few times. I switched to Red Line MT90 and the sticking immediately stopped. So...
Try tapping the OD bell and listen for a "ding" as the OD ring snaps back. If that does not help, then check the solenoid adjustment to make sure it is allowing the OD to disengage. Finally, make sure you switch to Red Line RT90. I think one of those will get you going.
tinman58
tinman58
I have been driving the car for about four years. The overdrive works as should be. Pops in and out no problem! I am using valvoline 20-50 in the transmission. Just flushed and new oil no change, probably have 5000 miles on the transmission. I don’t remember if the slipping was there before the rebuild.
sp53
This is an unusual one, I like it. This is a curve ball and a big guess, but so---anyways is it possible for a rear brake shoe to slip down and only be effective and drag in reverse?
steve
titanic
I think the springs that hold the clutch in direct drive would be at the top of the culprit list. They tend to weaken with age. But only an autopsy will tell.
Berry
CJD
All your descriptions still point to an issue with the OD. Anything else but the engine clutch would make grinding sounds. Detergent motor oil is not recommended in the OD, as the sun gears spin so fast they can foam the oil. I still highly recommend the MT90.
CJD
Just thought of one other possible problem...the engine clutch disc. I have seen very cheap discs where the center is not properly attached to the friction disc...but usually they let completely loose and have no drive at all. OD is still the most likely issue.
tinman58
tinman58
Thank you all. I think that I will remove the transmission and OD and have it checked out. I am glad that I invested in a car lift.
tinman58
tinman58
Just found this on Buckeye Triumphs! In the trouble shooting section
OD slips in direct drive (reverse): If the OD slips in direct drive in the reverse direction, then the sliding clutch is likely slipping in released position. The most likely cause of the slipping is weak clutch release springs. Another possibility is a damaged clutch sliding member. Wear of the clutch material is unlikely since the load on the clutch in the rear position is very small relative the forward position so any wear problems would likely show up in the forward position (OD engaged) first.
Madflyer
Things in agreement straight weight non det. oil SAE 90. If it moves in REV. then not gear box REV idler. leaves two clutch disk and springs in OD. Clutch B & B cheaper unit as to LUK is better unit. OD A or J ??
Call this guy if you want a TR trans guy. Ray Marty Gales Creek Or 503-357-5640 Say Andy sent you Reno NV. Madflyer
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
T General TR Another trans popping out of 2nd Triumph 14
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
AngliaGT Pontiac Trans Sport / Honda Insight Spotted 1
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
skystryd Trans and Diff Spridgets 7
G Trans Axle Parts Lotus 20
R General Tech Preserve eng/trans that has been removed Triumph 11
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
Superwrench For Sale 62 BT-7 Trans. and OD unit for sale Austin Healey Classifieds 0
doc50 NASH METROPOLITAN trans capacity? Other British Cars 0
RAC68 Alternate Trans/OD Oil Selection Austin Healey 17
doc50 Nash Metroplitan trans swap? Other British Cars 33
Bob Claffie Spitfire Engine & trans compatability Triumph 1
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
P 5spd Trans for Bugeye Sprite Spridgets Classified 14
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
S Smitty trans Master cylinder Austin Healey 21
C General MG Midget trans mounts MG 0
R TR2/3/3A Transmission fluid for 57 TR-3 Manual OD Trans Triumph 3
S TR4/4A Trans/OD gear oil? Triumph 14
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
D TR4/4A broken trans fork pin Triumph 14
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
histerical Dat Trans Spridgets 2
bugedd Datsun 210 Trans Question Spridgets 9
M TR4/4A Covers at side of H frame over the trans tunnel...ideas please. Triumph 9
K TR6 Thread repair for trans cover bolt Triumph 14
S TR2/3/3A driver side on the trans-cover? Triumph 11
tinman58 TR5/TR250 Trans swap Triumph 2
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
N Trans compatibility Spridgets 6
RAC68 Loud Trans Scrapping Noise Austin Healey 9
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
S TR2/3/3A overdrive trans Triumph 11
R GT6 GT6 trans issue Triumph 3
S TR2/3/3A Test an overdrive trans. Triumph 6
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
B TR6 Trans number decode Triumph 6
G Diff and trans oil Spridgets 8
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
RedTR3 TR2/3/3A Trans Gear lever interference Triumph 0
BlueMax Engine & Trans Finley In! Spridgets 27
doc50 TR2/3/3A TR3 trans issue Triumph 1
