TR6 74 TR6 - Transmission / Shifting gears
EWD
Afternoon Folks -
Car has been in the garage since last December being restored. Drove it before purchasing and it was shifting ok.
Drained oil and had no serious residue in the oil or on the magnetic plug. Just replaced the rear trans seal and found the shifter stuck in second. Removed top cover and inspected and everything appears ok. Refilled with new oil. Replaced top cover.
Shifting is firm but it still gets stuck in second. I found by depressing the clutch and rotating the drive shaft slightly (using a large screwdriver) it “unsticks” and I can shift again. Same for reverse.
So, my question - Is this normal? Should you be able to shift easily with the engine not running?
Thanks,
Will
Madflyer
I think for the most part it can shift to any gear from any gear 1st 3rd 4th to 1st. My car parked I move to Neutral and start car with clutch out ( no load on dry thrust bearings ) Looking at gears from top my not see reason, the synchro aid into gear not out ( I am open if wrong ) your brass forks my be worn flat pads on end will show wear leads to limited travel. Gears are not square cut but curved so movement requires some small turning to come out of gear. By rotation shaft and gears you help it slide out. Reverse on the other hand is square cut with out synchro and is also the shift lever is caged as not to go 3rd to Rev. and light lifting of shaft lever makes it easy. Madflyer
CJD
If the boxes sit for long periods the oil at the top of the box...i.e. around the entire shifter apparatus, tends to turn to varnish and get sticky. My TR2 was so stuck that a PO had bent the shift lever trying to get it out of gear...all due to varnish. If you are in a position to pop the cover again, you can clean it thoroughly with carb cleaner to free it up. If not, don't sweat it. Once it gets running and used regularly it should loosen up. Oh, to finish my gearbox's story, there was no damage to the box even after a guerilla bent the shifter lever!
EWD
EWD
Thanks guys. I cleaned the gears with WD40 (sprayed heavily and drained) and refilled case from the top. (Great advice and help from Madflyer). Everything appears clean and lubed. Just wanted to make sure before I put all this back together and install the trans cover.
Thx.
Madflyer
Heads - up on replacing cover that you did not move any gears and the Rev idler bell cam on left side Idler it should be towards center of case so cover goes in correctly and not in any gear. I say that because I helped another TR owner who when replacing cover slipped gears and shifter did not shift. I am in Nevada he is East Coast so Pictures E-mails and phone time to talk him back to a working trans. I also recommend WD 40 for cleaning. Kerosene is the only other fluid to use as it leaves an oil film. Madflyer
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
C TR6 TR6 Transmission Triumph 5
EWD TR6 Rear Transmission Seal 74 TR6 Triumph 4
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
hondo402000 TR6 New Transmission parts for TR6 Triumph 5
hondo402000 TR6 new TR6 transmission popping out of gear Triumph 6
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 Transmission Seals, TR6, where to get them Triumph 2
hondo402000 TR6 Leaking Transmission solved TR6 Triumph 5
hondo402000 TR6 TR6 Transmission leak Triumph 5
bobh TR6 New TR6 Transmission Conversion Triumph 3
V TR6 Need a Transmission cooler for your TR6? Triumph 4
cmacmillan TR6 Cleaning the transmission on a TR6? Triumph 18
SCguy TR6 Transmission Swap in my TR6 Triumph 14
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
R_Lyle TR6 TR6 Transmission rear seal removal Triumph 4
Paulus TR6 TR6 Speedometer problem in transmission housing Triumph 5
G TR6 [TR6] removal of front transmission seal Triumph 5
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
J GT6 TR6 Transmission w/OD in a GT6? Triumph 9
Slider748 TR6 Re-installing TR6 transmission Triumph 14
Slider748 TR6 TR6 transmission removal problem Triumph 12
71tr TR6 Transmission Rebuild [TR6] Triumph 2
A TR6 TR6 Transmission Identification ??? Triumph 3
A TR6 TR6 Transmission Rebuild Woes Triumph 2
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 0
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 20
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
