TR2/3/3A Which choke cable
TomMull
My choke is a PITA. I need to pull it with all the strength my aging hand and fingers can muster and still if I have a helper push the lever from inside the engine compartment it moves a bit more quite easily.
I've done all the stuff suggested for this condition, oiled the cable, rebuilt the carbs, polished the jets and followed the linkage diagram posted by the late Randall Young.
Next step seems to try a new cable. The one I have seems to be a replacement as it doesn't seem to have the stops of the original or if it does, they don't stop.
The question is which replacement cable? Moss and others list 2, a "replacement" and a "reproduction". What is the difference? I think one other supplier lists a twist lock cable too but my main interest is to get the chokes to operate fully and the locking or stops just a small bonus.
Any recommendations?
Tom
CJD
The twist lock cable is the original style. It is a bit easier to pull if you twist first, as then it misses the detents, which add a bit to the pull force. I would assume the repro is the twist lock style, and the replacement just a simple friction cable.
One other thing to check is the cable is in close proximity to the heater core. It is easy for the cable to get a sharp bend right as it exits the dash to clear the heater. Once it has a sharp bend it is forever hard to pull after that.
sp53
I got the original twistable from Moss and it is a good reproduction. It does not take too much to pull. These chokes can be fiddly sometimes; they foul up right at the choke cable holder on the front carb and need to have that clamp just right for the angle to slide. Maybe even a slight arch and wiggle room there. What John said also and perhaps your clicker inside slipped or wore out. I twist mine to the right also then pull and I would bet you could pull it without too much effort.
steve
dbenichou289
I am following this as well as I just installed a "replacement' style and it is tough as nails to pull. I have gone though the carbs and linkages and all work smoothly. I also do not see any kinks or sharp turns in the cable, and I oiled the interior cabling with lubricants. ...Still difficult to pull. Not sure where to go from here...
TomMull
TomMull
I have the original cable in my other TR3 project car. I plan to put it in my driver TR3 tomorrow. Will post result here. Tom
6TTR3A
The choke assy. sold by TRF is a pretty good copy of the original Lucas unit with one exception:
The tiny "D" shaped piece that locks into the cuts on the brass shaft is way too big. They are a pain to trim,
but doing so makes the pull tension a little bit better. I finally left that part out since once the engine caught
the set screw on the idle linkage can be set to keep the idle speed up until it warms up. I still wasn't completely
satisfied so I disconnected the choke linkage from the front to the rear carb and Viola! Easy-peasy !!
F
Graham H
I modified my choke by fitting a new outer and inner cable from a push bike shop. The new one has a nylon lined outer and allows the multi strand inner to move with ease a bit of a fiddle but works much better.
Graham
mastaphixa
Bronze
Grahm,
Can you provide details of your choke cable modification?
Steve Baker
TomMull
TomMull
I've found the cable from my project car and this is probably a matter of semantics but it might be more appropriately called a twist to unlock. The reproduction cable that is in my driver is a twist to lock. It has no detents but probably some sort of eccentric that locks it when you twist. Unfortunately the one from my project car will not be usable unless I can find a way to replace the cable core and jacket. I don't know if anyone's done that but I'd be interested if you have. I could probably get away with just replacing the core.
Someone put a retaining clip on the support behind the heater in my driver that holds the cable in a nice direct route through the firewall.
Tom
sp53
Does the knob come off both cables? I used a guitar string for the inner cable-- been there for many years--- and a small piece of stainless steel washer for the D clicker and I cannot remember what I did for the outside or if I replaced the outside. I think I solder one once with a piece of wooden dowel to keep the hole open.
CJD
Guitar string...I like that idea. Starting with a washer is a good idea too...I spent a lot of time making the little half moon lock from scratch. Starting with a washer would have saved a lot of time!
TomMull
TomMull
The knob on the original cable is held on by a spring loaded pin and comes off easily. The replacement cable is the same although the placement of the pin looks different. The knob on the replacement cable is loose also and moves almost 1/4 inch on the shaft, a result I assume of the force I and the PO had been using to start the car.
I hope to retain the knob on the original cable anyway. Actually got everything to work on it after a day or two in penetrating oil but I'll replace the 60 year old core anyway.
Plucky solution with the guitar string too.
Tom
sp53
Forgive the dirt, I drive this car hard and hang it up wet, I live in western Washington the evergreen state. The guitar strings come in different diameters, also.
R TR6 TR6 Choke Cable Triumph 11
D Choke Cable Length Austin Healey 0
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
D Carb Choke Cable Austin Healey 9
M TR6 1973 TR6 - broken choke cable Triumph 6
T TR6 TR6 Choke Cable Lubrication Triumph 5
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
K Choke cable replacement Austin Healey 1
F TR2/3/3A Choke Cable Problem Triumph 29
edkap2002 TR6 72 tr6 choke cable Triumph 4
TRMark TR4/4A Choke Cable Routing Triumph 3
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
S TR4/4A aftermarket choke cable Triumph 3
M TR2/3/3A Choke Cable Detent Device Triumph 11
Rob Glasgow Choke cable turnion Austin Healey 8
trrdster2000 TR6 Double Choke Cable Repair Triumph 0
E T-Series MG TD choke cable MG 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B TR2/3/3A Choke cable detent Triumph 4
B TR2/3/3A choke cable attachment Triumph 14
B BJ8 choke cable Austin Healey 0
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
KVH TR4/4A Choke Cable TR4A Triumph 5
W New choke cable install Triumph 1
af3683 TR2/3/3A New TR-3 Choke Cable Triumph 7
Tinkerman TR2/3/3A TR3A Choke cable hook up Triumph 3
J TR4/4A TR4 Choke Cable Routing Triumph 4
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
af3683 TR2/3/3A TR3 Choke Cable Triumph 17
bugedd Choke cable repair help Spridgets 3
af3683 Choke Cable Connection to Rod Assembly Fork Triumph 7
R choke cable Spridgets 6
jsfbond Choke cable [square knob] Triumph 0
UmmYeahOk GT6 Choke Cable for a 67 GT6 Triumph 4
Editor_Reid Needed: Choke Cable for BN2 Austin Healey 0
memphis Choke Cable Austin Healey 1
M stromberg choke cable config. Triumph 8
M stromberg 175 choke cable? Triumph 2
G Which choke cable should I use for euro 1500 carbs Spridgets 8
T ID a choke cable Triumph 3
H Choke Cable Return Austin Healey 14
T Choke cable Triumph 1
Tinkerman TR2/3/3A TR3A Choke Cable Questions Triumph 2
jvandyke choke cable length Spridgets 11
H Throttle cable and choke cable holder MG 3
drooartz Choke cable connection? Spridgets 8
Nelson Choke cable connection? Spridgets 5
J TR6 75 TR6 choke cable problems Triumph 4
