TR2/3/3A Upper Wishbone Bushings
ricadamdonk
So I searched the forum and found lots of good advice for this job and was ready for an enjoyable day in the garage.
Unfortunately my upper ball joint had other plans. Somewhere along the way this joint was replaced with one without a castelled nut for the wishbone end
and for the life of me I could not loosen that nut. Assuming that it may have been assembled with high strength thread locker, I heated it up
with a propane torch for quite awhile and was still unable to budge it (I did succeed in rounding the flats a bit!). I think my best bet now is to split the ball joint, unbolt the upper fulcrum pin, and deal with it on the bench.
Any advice greatly appreciated!
Cheers
Frank Canale
Hi Bob, is the body on the car or off? Either way I would cut the nut with a dremel, maybe there is room for a small grinder with a cutoff wheel, or use a 90 degree die grinder and grind the nut to the point you can break the nut with a cold chisel. The nut is the weakest link so that is what I would attack. Frank
jfarris
Consider a Dremel with a flexible shaft and a full container of cut-off wheels. The flexible shaft is great for both control and tight spaces.
Good luck!
sp53
Have you tried a large bar between the ball joint and vertical link then apply pressure against the two to hold everything tight and use an impact gun or drill with a socket and snap the nut lose.
steve
Frank Canale
Kroil is good stuff. But once the nut is rounded off you have to use a more aggressive approach. This is a tough spot to work in. Frank
R
ricadamdonk
Thanks all for the tips. The body is still on so I think I will try a nut splitter first and see how I make out.
Cheers
R
ricadamdonk
Mission accomplished.
I split the ball joint and picked up a nut splitter from Princess Auto (our version of Harbor Freight) and proceeded to go to town. After several turns of the wrench a satisfying pop was heard and I thought the job was done. Unfortunately that was the sound of the splitter failing (seems they don't make cheap tools like they used too!).
At any rate, I was able to lift the arm up enough to get a long box end wrench on it and free the nut. Now that the wishbone is off, I see that the splines are worn on the hole for the ball joint.
Is this critical for reassembly?
Cheers
sp53
Never been sure if those slots were made by the ball joint or they come that way new. The new ball joint will have the splines and they will cut into that thin metal. I do not like many aftermarket parts, so I would use that one unless you have a better one. I mock up the whole assembly and see how everything works as a whole then move that to the car. The wishbones overlap sometimes better one way than the other. The inside of the wishbone where the rubber goes is often pitted; what I do there is clean the inside high spots up with a file or something, but not too much and go with that. I have good success.
steve
CJD
+1...the splines are from the ball joint as it holds itself from turning. You are fortunate, as I have had the ball joint turn as it came off before, and that opens allows the spines to open up the hole so the arm cannot hold a new ball joint. But you are good to go!
CJD
remember, the splines are actually on the ball joint post, not the A arms. What you see in the arms is the result of the ball joint splines biting into the arms. The new ball joint will cut it's own new "splines" into the arms.
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
mt10flyer TR2/3/3A poly bushings - upper wishbone Triumph 2
KVH TR4/4A TR4A Upper Wishbone Bushings Triumph 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
J TR4/4A confirm upper wishbone arms Triumph 11
PatGalvin TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn? Triumph 6
bigjones TR2/3/3A TR3A Upper Wishbone - Bush R&R Triumph 16
jerrybny Upper wishbone arms question Triumph 6
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Rut MGB 62-67 upper MGB steering shaft MG 3
P MG TD Bonnet Upper Sections MG Classifieds 0
pkmh BJ8: Upper Trunnion Rebuild [Of Continuum] Austin Healey 9
L TR2/3/3A Upper steering column bushing Triumph 8
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
D 62 tri-carb upper fulcrum pins Austin Healey 4
J TR4/4A Upper steering flex coupler Triumph 4
R TR6 Body Parts Source, Upper Midwest Triumph 6
S TR2/3/3A lube for upper A bushings Triumph 2
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
KVH General TR Upper Control Arm Reversed? Triumph 5
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
vickxxx TR2/3/3A Upper cylinder oiler Triumph 8
B TR2/3/3A Upper Control Arm - which overlaps which? Triumph 2
GTP1960 TR2/3/3A Tire condition, upper side wall splits...dangerous? Triumph 12
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
S TR4/4A Reversing upper fulcrum link Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
Morris OOS Upper Link Spridgets 6
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
T TR4/4A Upper steering column Triumph 3
G TR2/3/3A Steering Box Upper Bearing Race Triumph 1
C Sway bar upper installation help please Austin Healey 3
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
V Upper Ball Joints Triumph 16
B Upper radiator stay rods black or body color? Triumph 11
bcbennett '74 upper radiator hose Triumph 5
T TR2/3/3A TR3A upper windshield seal Triumph 12
I TR6 TR6 upper A post seals Triumph 0
T TR2/3/3A TR3 upper A arm bushings Triumph 6
D MK2 upper radiator hose question Jaguar 3
K loctie upper rod bushings Triumph 4
memphis Door Panel - Upper Piece? Austin Healey 8
JPSmit fixer upper Spridgets 5
Morris Upper link triangulation Spridgets 0
Steve An Upper-Crust Spot Today Spotted 4
