"A" Pillars: A Question
Lin
I have never before noticed the change in the "A" pillar on the Big Healey. On my BT7 (first photo) the "A" pillar is completely flat while the "A" pillar on the later car (I believe a BJ7 in the second photo) has an offset at the bottom of the pillar. Just curious about the change. What purpose does it serve and why was it done?
Thanks!
Lin
HealeyPassion
Re: A curiosity question
Roll up widows started with BJ7, maybe that has something to do with it.
I agree, I always thought it had to do with the roll-up windows. That said, looking at my roll-up window doors, I don't see why it was necessary... possibily additional structurally rigidty due to the additional weight?
And, who is that young guy laying under your BT7 in the first construction image?
Steve
Lin
Lin
Steve,
That would be me about 12-13 years ago when I still had some dark brown in my hair! Son John helping with the Toyota 5 speed fitment.
The roll up window explanation certainly seems plausible, and while not doubting that reasoning at all, I still wonder.
Lin
red57
I've never had a BJ so just speculating here but it looks to me like like the door hinge line (pillar) is a lot more vertical than the roadsters - in the roadsters it is parallel to the door edge/opening.
I think it is related to the roll up windows because they got a lot heavier and it looks like the doors don't swing upwards as much. They would be easier to open and easier for those clever door stops to hold open - on my roadster they really struggle to hold the door open and I'd bet they would have a much harder time with the additional weight of the glass and hardware.
If I'm right, that would require the jog in the bottom so the fender, door and rocker joints could stay visually the same on the outside.
I'm curious too so hope someone responds who knows for sure.
Dave
I had always thought it was due to the wrap around windscreen* so I guess you could say rollup windows and not be wrong ;)
*So that raises the question, are the A-pillars set further back, or does the base of the windshield protrude further forward in the middle of the cowl...?
Who has both, to compare?
Jerry
I don't know the answer on the pillars but I think Lin needs a lift so he does not have to work on the ground! Best investment I ever made!
Lin
Lin
Hah. Shortly after that photo was taken I purchased a lift. One of the best decisions I ever made!
Lin
bob hughes
Cor! I'd love one.
I have the money to buy one but the conversion on the garage roof to get it in, and use it, would cost a fortune, especially as it is connected to the garage next door and is a 'flat' roof across the two garages and slopes from front to back. :sorrow:
:cheers:
Healey Nut BT7 Windscreen Pillars Austin Healey 4
D Windscreen pillars Austin Healey 7
60Bugeye Polishing Cockpit Surround and Window Pillars Spridgets 41
PAUL161 T-Series TF Wood Hinge Pillars? MG 2
1 Replacement door pillars, aluminum? Austin Healey 6
JamesWilson Mounting "A" pillars and doors... Austin Healey 3
W 59 BE Windscreen Pillars Spridgets 5
DonC1948 TR6 A "CLASSIC" question. Triumph 6
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
K TR2/3/3A Brand new brake caliper question... Triumph 8
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
R TR6 question re: Engine Oil Triumph 3
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
