Clutch Disengagement
Michael Oritt
Lately I haven been noticing that it takes an increased amount of effort to shift from gear to gear--up or down--no crunching, no grinding, just resistance. During a drive today I tested the disengagement of the clutch and with the car in first unless I have the pedal hard down against the floor there seems to be a slight but perceptible bit of engagement and the car will creep very slightly ahead on level ground. This suggests to me that the clutch pedal is not being all it can be and while I have not yet been under the car I am wondering if this is more likely to be a hydraulic issue (primary or secondary cylinder) or one involving the linkage--wear on clevis pin, egging out of holes, etc.
What's the best way of diagnosing an issue such as this?
pdplot
Re: clutch [I think] question
On the TR6, lay down on the floor, reach in and remove the cotter pin holding the clevis pin and examine the pin for wear. Mine was worn and will be replaced with a new one sourced from my local Ace Hardware store. For the egged-out hole, I Googled clevis pin and came up with a blog MGA With an Attitude setting forth with pictures how the owner repaired a worn hole by installing a bushing in the pedal. The Healey is probably similar. Mine will hopefully be repaired this week - but not by me.
Healey Nut
Chances are the hole in the slave cylinder rod and the Clevis pin are worn out so you not getting the full benefit of the slave cylinder operation .
get the car up in the air or pull the tunnel and have a look see .
When does the pedal start to engage? There should only be an inch or less of free play in the pedal; if more, it's likely a hydraulics issue.
roscoe
If your clutch master cylinder is fastened to the welded on peg that was formerly the pivot point for one of the clutch linkages, be sure it hasn't managed to rotate on the peg. I don't know what the Smitty kit was like when you installed yours but I had to do some home engineering to make sure the one I just installed would remain solidly in position.
johnea
Had exactly the same fenomenon on my MGB. Rebuilding the slave cylinder did the trick. Although clean and dry from the outside, the inside of the cylinder was really dirty.
Michael Oritt
Michael Oritt
I jacked up the car this morning and observed the clutch linkage operation while actuating the pedal from underneath. Beyond the initial 1/2" or so of free play at the top of the pedal there was an additional bit of slop caused by the pedal's rotating on the transverse shaft, indicating wear in either the bolt that passes through the shaft or the hole--or both. I did not have time today to do more than tighten down the nut, which eliminated the excess slop and appears to temporarily the problem, though a permanent fix will come from getting a new bolt through the hole. More tomorrow....
Michael Oritt
Michael Oritt
Bob--
No, it is hydraulic--actuation is via the clutch connecting lever to a short pushrod to the master cylinder.
Presumably, you don't have the graphite 'donut release bearing, so it's gotta be air in the hydraulics or the slop you already mentioned, or a combination.
Michael Oritt
Michael Oritt
More shall be revealed when I drive out the bolt and replace it--hopefully tomorrow.
BTW if you look on p. 47 of the MM catalogue it is pn#25 that activates the pushrod of the clutch MC
pan
G'day Michael,
At first I ignored your question because I knew you had swapped the Austin transmission for a modern 5 speed, so assumed your clutch release was hydraulic and therefore outside my experience. But your recent comment about the cross-shaft prompted this reply. Many years ago I had similar problems and finally worked out that I was suffering from a loss of travel, that is, the first lever (attached to the inner end of the cross shaft) was not rotating by the same amount as the pedal. When I withdrew the shaft I found that it had split lengthwise and was twisting as the pedal was depressed. I thought this might be a common problem with BN1s & 2s, but I have never heard of another car having the same problem. But it's worth a look!
Cheers,
Alwyn
Michael Oritt
Michael Oritt
This morning I drove out the 5/16" bolt securing the clutch pedal to the transverse clutch operating shaft and found that the threaded portion of it ran up and past the hole in the shaft which no doubt contributed a bit of slop to the clutch pedal's effect. I replaced it with a grade 8 bolt whose shoulder comes clear of the pedal where it rides on the shaft and after tightening things down almost all free play in the clutch has disappeared. A test ride revealed that shifting was indeed easier and there was no creep when the car was in gear with the pedal depressed. I plan to rebuild or replace the master cylinder and when I do I will check the bolt that fastens the clutch connecting rod lever to the shaft for proper shank length as well and possibly gain a little more motion.
In answer to Bob's statement/question "So the Toyobox keeps all the wonky hardware of the 100 clutch?" the answer is no--all of rods, levers, etc beyond the clutch connecting rod lever are gone and that lever operates directly on the mc shaft. There are probably other ways to install an hydraulic clutch on a 100 but this is what Smitty came up with when we did the install at his shop in CA. After returning to MD I swapped in a BJ diaphragm clutch for the original spring clutch which made for much smoother and lighter operation.
njunear
Bronze
I followed this discussion with interest as I had a similar issue with out BT7-II many years back. Much worse, but similar. Shifting into gear after starting the car or from a stop - reverse or first, did not matter - was always accompanied with mild grinding of gears. Was bad enough that I would start the car in gear with the clutch depressed. When it got bad enough that I took the plunge and tore everything down, I pinned the issue mainly on the graphic donut throwout/release bearing. It was worn to the point that the clutch was never fully releasing. And I certainly was not making things any better by starting the car 'in gear.'
I bring this up to also point out how close I was to a catastrophic failure. There was still a tiny bit of material left on the clutch disc before the rivets would have dug in to the flywheel. But the heat from the slipping clutch that the flywheel had developed severe fire cracks - see pics attached.
Turns out all the linkage was fairly good although I did replace both clutch cylinders and clevis pins, the latter just to tighten things up.
Anyone need a good boat anchor?
... In answer to Bob's statement/question "So the Toyobox keeps all the wonky hardware of the 100 clutch?" the answer is no--all of rods, levers, etc beyond the clutch connecting rod lever are gone and that lever operates directly on the mc shaft...
I felt I could disparage the original setup because I have it in my BN2/100M. I thought it would work like crap, but was pleasantly surprised; it actuates almost as smooth as the hydraulic system on my BJ8. I might spring for the DWM upgrade someday.
Michael, sounds like your clutch setup is now similar to the stock braking setup.
T TR6 TR-6 Clutch disengagement issues, recurring or solved ? Triumph 6
S Clutch Disengagement Issue Triumph 20
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
T TR2/3/3A TR3A clutch problem Triumph 15
S MGB 1978, replacing the clutch. MG 3
S MGB clutch replacement MG 7
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
D BJ7 Clutch Austin Healey 6
K TR2/3/3A An Unusual Brake and Clutch MC Set Up? Triumph 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
