Acceleration Problem
dancrim
65 BJ8, starts right up (even when cold) and runs great, but after it heats up and I park for 10-15 minutes it starts right up and when I accelerate it acts like it wants to die and then takes off. Does this for a minute or two, then runs fast and strong.
It's like you're pressing and letting up on the gas pedal.
Any ideas?
Thanks.
Any ideas?
Thanks.
Yep. Due to engine compartment heat, the fuel in the line in the engine bay has vaporized, creating a bubble. My BJ8 does exactly the same; I think you'll notice that acceleration and running return to normal commensurate with the temp gauge dropping. This is, most believe, including myself, due to ethanol in the fuel (my car started doing this about the time ethanol became common in gasoline here in California). There are lots of threads on here on overheating engines, but remedies that might help keep the engine cooler when driving probably don't help much, as the latent heat after shutdown is greater than when running (on a hot day the temp gauge will often go to 212deg--boiling--at shutdown). Keeping the running temp as low as possible could possibly help. FWIW, I had my exhaust manifold ceramic coated and wrapped my downpipes, and didn't notice a difference either in running temp or after shutdown.
Edit: SU carbs require fuel pressure between 3-4psi (I think 'spec' is 3.5psi). Theoretically, a higher pressure pump might overcome the bubble faster, but SU carbs wouldn't like it (anyone tried this?).
steveg
Wrapping the engine compartment fuel lines with heat insulation could help. My wife's '73 Z-car originally had a vapor lock problem with its mechanical fuel pump. A factory recall fitted an additional SW electric pump and wrapped all the engine compartment fuel lines in a silver-coated fiberglass insulation.
dancrim
Thanks guys. Kinda what I wanted to hear instead of some weird carb. or electric problem. And you're right, it does clear up
after a mile or so of driving. I'm in Louisville, and all the gas is ethanol-laced. Will try your ideas and post a result. Thanks again.
BN6_L1232
dancrim-I had a similar issue with stumbling acceleration especially after stopping at the end of freeway ramps and taking off from that point. I think I have solved the issue by using a cozy like device fitted over the SU Carb bowls sold by Joe Curto called "Koolmat Koozie". This when combined with a thermal wrap on the carb interconnecting fuel line by Thermo-Tec (17075 3/4" X 36"). Seems to work so far. See image attached. Peter. Cozy.jpg
D Acceleration problem. Austin Healey 15
D Acceleration problem Austin Healey 4
H Loss of Power Upon Acceleration Austin Healey 8
J MGB 73 getting loud squeal with acceleration MG 11
P TR2/3/3A Hesitation on acceleration, wants to stall at corners Triumph 5
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
J TR6 Chirp or squeak on acceleration Triumph 11
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Hesitation during acceleration Triumph 13
KVH General TR Power Issue on Acceleration Triumph 13
J TR2/3/3A TR3a stalls on hard acceleration Triumph 4
JAV stumbling on acceleration Austin Healey 14
T power under acceleration Austin Healey 15
bighealeysource BN2 missing on acceleration Austin Healey 11
W pops out of second gear on acceleration Austin Healey 12
R Sprite misses during acceleration Spridgets 7
Rob Glasgow Stumble on Acceleration Austin Healey 28
D Carburetor Backfire on acceleration at low speed Austin Healey 18
Jim_Newman Unintended acceleration Austin Healey 3
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
blackdog in gear acceleration Austin Healey 2
Stewart Machine gunning on acceleration, loss of spark MG 8
JPSmit Always something - acceleration question Spridgets 6
D Acceleration and Hot Start Issues Spridgets 7
S car veers on acceleration Austin Healey 5
Tim Tucker Running Lean after hard acceleration... Triumph 7
emann miss under acceleration after warming Spridgets 9
Baz Acceleration.. Spridgets 14
Aldwyn Hesitation at Acceleration Triumph 21
M Acceleration Fixed MG 1
A Acceleration issue Triumph 5
A Poor acceleration when hot Triumph 5
Webb Sledge Coughing Under Acceleration Triumph 4
KLUTZ Wedge TR7- Spitting & Caughing at quick acceleration ?? Triumph 9
C Stumble in acceleration... easy fix? Triumph 11
C Hesitation under acceleration and at 3k? Triumph 8
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
