BJ8 flywheel take some pounds off
Jerry
Anybody have a diagram of how they would lighten their flywheel? I have a machinist, but he wants some hints.
J
Jerry
Thanks Doug, I had looked at that site before. It shows some of the area to trim. I am not sure how they carved out around the mounting holes. I assume with a milling machine.
dougie
Hi Jerry -
Here's a few photos of the lightened stock flywheel I used on my vintager racer for years. You could use this same design for the street, just leaving a little more material on if you didn't want it as light. I think 25 lbs would be a good streetable weight.
J
Jerry
Good pictures Doug. I also was sent a very old healey magazine which gave how much metal to cut off, ie. 1/8 at the outside corner, 1/4 on the back side curve. I will see if I can post these and we will have it all in the same place.
Jerry
bob hughes
Hi Jerry -
Oooo not to sure about that Dougie, I took mine to Bill Rawles and he whipped about 6Lbs out of it. It ticks over well and is quite responsive.
:cheers:
J
Jerry
Read the text first then the picture and this will make sense. Helps a lot with Dougs pictures. Thanks Doug.
dougie
You're right Bob, I miss-spoke. The wine must have been talking, I meant to say 20lbs. would be a good street weight.
Or you can go with the "Full Monty" at 10lbs which I use on my racing big Healey.
dougie
Hey Dougie, How much HP do you get out of your racer engines?
Hi Jerry -
I get a lttle north of 250hp with most of my race motors at the wheels. This lastest build is a few levels beyond that....
HealeyRick
Hi Jerry -
That's pretty amazing. About what I'm getting at the wheels with my V8. Using Sunbeam Tiger cast iron manifolds from a 260 cubic inch motor really chokes the hp, but they do fit without really cutting up the car. Just what do you have to do to the Healey motor to pull that kind of hp?
J
Jerry
I have my friend's Huffaker Healey at my house during the fire season. The owners live in the boondocks and were worried as it is not street legal. When he raced it, the dyno on the engine was only 195 hp. I only drove it around my yard, but I could feel the power available!
John Turney
I've ridden in it, and it's definitely not docile.
dougie
Hi Jerry -
Does Phil still own the car? I corresponded with him a few times when he was thinking of selling it.
J
Jerry
Yes, Phil needs to sell it. He decided he is too old to race anymore and it needs to be driven. He has a 100 4 Healey and a Morris Minor so he still has lots of toys to drive. We are trying to decide where to post it for sale.
HealeyPassion
Really impressive Dougie!!!... full build specs??... or is that secret?
Steve
R Wanted BJ8 FlyWheel Austin Healey Classifieds 6
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
6 BJ8 Headlamp Wiring Austin Healey 1
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
