TR6 TDC - Position of rotor and wires
steveg
Hi All,
Have had my distributor overhauled & advanced by BVU and want to make sure all is as it should be on installation.
On the Healey at TDC on compression stroke, the rotor should point generally at the #1 spark plug, with the wires in the firing order (same as TR6) counter clockwise around the cap. On the TR6, that would put the rotor and #1 wire approximately at the 10 o'clock position, + or -.
Is this the way it's supposed to be? I couldn't find any info in the Bentley manual.
A picture of the distributor and wires would be appreciated. Thank you in advance.
poolboy
Normally the spark plug wire in the distributor cap for # 1 cylinder is at 7 o'clock....If it's not then the distributor drive gear was not installed in it's normal orientation so the spark plug wires were stuck in the distributor cap in a different position to compensate.
With #1 at TDC at the top of it's compression stroke the distributor drive gear would normally be clocked with the slot running 1 to 7 o'clock with the "big half" on the right hand side of the slot.
poolboy
The 'trick' Steve is making sure the distributor drive gear aligns with the oil pump shaft, if you do decide to go thru the process of reorienting the distributor drive gear.
steveg
steveg
Already done, thanks Poolboy.
I had missed BVU's point about moving the car back and forth until the drive gear seats on the oil pump, but noticed the distributor pedestal didn't fully seat due to the old position on the oil pump drive dog.
Made this tool from a 6" piece of tubing (dowel would also work) to turn the oil pump drive dog. The oil pump rotates easily. Used a magnet to lift drive gear out and rotate it.
M TDC on the Bugeye Spridgets 4
Geo Hahn TDC Check - Old Idea w/ a New Twist Triumph 17
M TDC question Triumph 7
mrv8q TDC Question Triumph 4
A T-Series Rotor orientation at TDC MG 2
jerrybny Figuring out TDC Triumph 3
G Finding TDC or Waiting For Godot Triumph 17
dklawson A-Series Dot-to-Dot Cam Setting [TDC?] Spridgets 3
Bayless Finding TDC on a flathead motor Other British Cars 16
DrEntropy T-Series So when is TDC not TDC?!?! MG 9
jerrybny TDC Tool Restoration & Tools 29
jerrybny How to find TDC Triumph 2
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
P Pedal Position Adjustment Austin Healey 2
A TR2/3/3A Seat position Triumph 2
Healey Nut Seat Base Frame Position Austin Healey 4
Jeepster Clutch Pedal Position Austin Healey 4
chicken Inner Door Seal Trim Position Austin Healey 6
B Roof vent position on BN7 hardtop. Austin Healey 15
G Valve adjustment and easiest way set cam position Austin Healey 15
L Seat position for a BN1 Austin Healey 0
Upland 3 position headlight switch is now 2 Spridgets 1
J TR2/3/3A Front apron position Triumph 9
D AH 300O MK1 Choke Knob Position Austin Healey 5
G BJ7 Window channel position Austin Healey 1
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
D TR2/3/3A Dipper switch position Triumph 13
W Cam gear position BJ8 Austin Healey 11
S TR2/3/3A how to position pieces when painting Triumph 7
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
S TR4/4A Ignition switch key position Triumph 2
J TR4/4A Horn clip position. Triumph 6
P bumperettes position BT7 Austin Healey 8
K TR2/3/3A Correct position for flasher bracket? Triumph 7
N TR4/4A no spark in start position Triumph 8
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
E TR4/4A TR4 Throttle shaft position Triumph 1
R TR2/3/3A Position of LTD fastener on new top Triumph 5
M Accelerator Pedal Position Austin Healey 4
J TR4/4A 175 CD needle position? Triumph 5
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
A TR2/3/3A TR-3A steering wheel position [measurment needed] Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
vette Seat floor position Austin Healey 10
B Spin on oil filter position Austin Healey 1
