Front Spring Removal For BJ8
pkmh
Hello All,
As part of my front end rebuilding on my 67 BJ8, a few months ago, I have already replaced the upper bushings and had my Armstrong lever shocks rebuilt. So, far all very good!
In attempts to do the lower bushings to the control arms, it will be necessary for me to remove the 4 existing 3/8" bolts securing the spring pan.
From my shop manual readings and elsewhere here, after the car is jacked up and wheel removed, I am aware how it is recommended to first place 2" wood blocking situated under the upper shocks first(to avoid crushing the rubber bumpers).
Then in sequential order of removing the spring, first remove two of the four existing 3/8" bolts diagonally opposite which secure the spring pan, then replace the removed bolts with 2-3/8" diameter by 4" long bolts, leaving the other two existing 3/8" bolts in place. Then remove the two existing 3/8" before slowly removing the 4" long bolts in attempts to relieve all of the compressive energy from the springs.
Assuming that is the way to go, then my two simple questions are:
1. Is it necessary to use grade 8 bolts (highest grade strength)? Is it possible to use a "Home Improvement" grade or other than a grade 8?;
2. I have a screw thread gauge which seems to indicated the existing 3/8" bolts used are (approximately) 26 screw threads/inch. Is there a difference in using coarse screw threads over fine? Maybe engineering properties to be aware of using one type over another?
Not sure how much compressive strength is stored in a spring. Any thoughts?
Paul
steveg
Next time I use these, will probably put roll pins through the large nuts on the right, as the jam nuts tend to loosen. Tack welding would be good here if one has it. Right-hand ends also staked to keep jam nuts from coming off end.
The two large 'spacer' nuts make the jam nuts easier to access below the spring pan.
Electric (or other) impact wrench makes short work of spring removal:
The threads on our cars are almost entirely fine thread. Spring pan bolts are 3/8-24.
Like Steve's. GREASE the threads, as that's where all the load is concentrated. Last time I saw these in the toolbox drawer, they were much shorter...
EDIT: the all-thread coupling nuts are an easier target to hit when you're throwing a wrench at them. A ratcheting box wrench is worth its weight in gold here.
Healey Nut
The above listed methods are great especially for reassembly . However when the car has been together for an eternity and bolts are weak and rusty the chance of you removing two diagonally opposite bolts without shearing them off is questionable .
Get yourself a cum-a-log chain hoist . Wrap it below the spring pan over the top of the shock mount plate making sure the chain cant slip off . Take up the tension a bit on the spring , shear off the the old bolts , relax the cum-a-long and spring tension and your done .
Obviously you are going to damage paint etc but if your rebuilding the front end chances are you are going to be doing some repainting .
Theres no way I would rely on two rusty old bolts to hold that spring pan tension in place while I have my head close to it trying to punch out rusted bolts that sheared off or trying to get new bolts through corroded holes in the A arms
Manuals are great, but one needn't follow them to the letter; you could swap out ONE (1) bolt at a time for the all-thread, and still have a safe approach to releasing the kinetic energy stored in those springs.
EDIT: you could place a C-clamp on the A-arm/spring-pan while each bolt is swapped out too...
Without being overseen by a trained/certified rigger, I'd be reluctant to trust a come-along to stay in position throughout its travel. Although, with the proper placement of lifting eyes to limit/direct the chain-links placement, securely welded to the shock arms and lower control arms, I suppose it's within the realm of a home-shop mechanic ;) ;)
4ZX44_AS02
Healey Nut
4ZX44_AS02
True to a point Randy but I always err on the side of safety especially when things like stored energy (ie spring tension) are concerned .
I am a certified rigger by nature of my work and have used the method I listed before for the reasons I stated . The old bolts simply sheared off when removal was tried On both my cars and the portion in the A arm could not be removed until the A arms were off the car and they were heated etc to allow the sheared portion to be punched out .
You would wrap the chain right around and hook the hooks together , make sure the operational part of the chain hoist is on the side of the pull so it’s accessible and easy to operate . No need for lifting eyes welded anywhere .
The other thing to consider is how rusty and corroded the spring base pan maybe ? They are notorious for being rusted partially through and hence weakened .
steveg
I originally used four of the all-thread setups, but two placed diagonally is all that's necessary. Skeptical of this? Make 4 and try it out. Maybe it's necessary with the 2" block setup.
The advantage of the locked nuts at the bottom is you can use an ordinary ratchet wrench, or an impact wrench - all the slack is at the top.
The length I've shown works with my poly bushings as I'm not using the 2" block under the shock arm. I do use a jack under the lower trunnion in order to lift the spring pan away from interfering with the frame. Suggest starting with longer allthreads and trim as needed.
I haven't had problems with sheared bolts - kroil unsticks them every time. Just successfully used Kroil with rusty bolts rebuilding the front end on my TR6.
These are worth their weight in gold:
pkmh
pkmh
Thank you all for your advice on removal. I like the roll pin approach with the spacer nuts, which seems to me that spacer nuts can take on more stress loads than say, standard dimensional nuts as found on the spring pan.
I also have an old set of spring compressors that I once used when I had a TR6 many years ago. Though not sure how they would fit on a Healey, given the fact the spring pan is solid and I think the TR6's pan were open at the bottom. But my memory has slipped a bit. But I will check that out and get back here, (eventually).
Thanks again!
Paul
B TR2/3/3A Front spring removal Triumph 4
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
T TR2/3/3A Rear spring front pin removal Triumph 28
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
M Removal of Front Leaf Spring Bushing Triumph 3
JPeter TR2/3/3A TR3 Rear Spring - front pivot - removal Triumph 18
P MGB 1974 MGB front spring length. MG 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
A Wanted Front Bumper Brackets/Spring bar assembly for 100-6 Austin Healey Classifieds 0
C BN1 Front Spring Advice Austin Healey 0
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
KVH TR4/4A Front Coil Spring Spacers Triumph 1
bugedd Front spring isolators Spridgets 1
C TR4/4A SuperPro Front Spring Packing Triumph 7
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
K TR2/3/3A Rear spring again....front pin "D" washer? Triumph 7
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
J Rear spring front pin stuck Austin Healey 8
J TR2/3/3A Removing front spring pans? Triumph 6
M Jaguar LH front door hinge spring Jaguar 6
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
H front spring installation Austin Healey 21
R front spring install Austin Healey 23
JBBgt6 GT6 TRiumph GT6 Front Suspension [Spring Pan] Triumph 2
B Wedge TR8 sagging front spring preference? Triumph 5
T MGA Height of stock front spring on MGA MG 2
M Healey 100-4 Front Spring Stiffness Austin Healey 2
Foghat73 MGB Spring compressor for MGB front suspension MG 45
T Powder coat or paint front spring pads and arms? MG 37
G Choosing the correct front coil spring Spridgets 54
N TR6 TR6 Front Spring Height?? Triumph 3
Atrus Leaf Spring Front Bushing question Spridgets 6
Z BN1 Front Spring Dimensions Austin Healey 7
J front spring size - help! Triumph 6
S building front spring compressor Triumph 24
G Front Spring I.D needed. MG 2
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
JPSmit Front Spring Question Spridgets 7
S front/rear coil spring diamaters. Triumph 4
Darwin Front spring height? Triumph 3
ChrisS Front spring hanger Spridgets 0
IanF Spitfire Spitfire front spring questions... Triumph 13
C front spring change Austin Healey 2
77MidgetMkIV front suspension rebuild [spring refit specificall MG 9
B Spitfire Spit Mk1 Front spring rate/value. Triumph 7
bighly help-extracting [front] leaf spring pins Austin Healey 5
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
