TR6 Stromberg Bypass Valves - Question
Sbardon
I am currently chasing a poor vacuum issue, and along my path am into the bypass valves on the carbs.
1976 TR6 Vac retard.
I am a bit confused as the gasket that mounts the bypass valve to the carburetor has a section missing between the two ports?
I understand that:
There is a signal port (the tiny one), A port on the manifold side of the throttle plate, and a port on the Carb side of the plate. When the manifold depression exceeds the setting the valve floats and allows more air from the carb to the manifold side...
I seem to have old gaskets that have the bridge between the two larger ports, yet I also seem to have some without, which makes no sense to me as there would be a constant leak across this gap.
(In looking at the Moss Kit, it seems to provide both?)
Does anybody have any insight?
poolboy
Depending upon what you see on the carb itself.
If there is a channel between the inlet and outlet like this, use the gasket with the open space between the 2 holes.
Having said that you'll have less problems in time to come if you disable the TBV entirely.
And, btw, it's not just air that bypasses the throttle, it's whatever the mixture happens to be in that short interval of time that the TBV is forced to open.
S
Sbardon
Poolboy, thanks.
In the picture you provided, I see the gasket with the space, I don't see what you mean by the channel in between.
Both my carburator and bypass valves have flat surfaces.
Are you saying this means I should use the gasket that has material between the holes?
(would make sense to me)
And why or for what carbs would you want that channel(leak)?
S
Sbardon
Poolboy, thanks.
poolboy
See the channel or gap or whatever you want to call it between the hole to the mixing chamber and the hole to the manifold in that picture ?
If your carb has that then you'd use the gasket on the far left in this picture.
No channel then the gasket on the far right.
Carbs from a 250 or a 69 or a 74, the gasket in the middle.
I didn't design them, I just rebuild them....:crazyeyes:
S
Sbardon
Poolboy, thanks so much for your reply, I am afraid that old eyes and old phone mean I don't really see what you mean by the channel. In your picture it appears to me that there is a gasket in place, and the gasket is missing material between the holes.
The ones on my units were the ones on the left in your second picture(most likely not original). Wondering if they should be the ones on the right.
poolboy
Apparently your eyes are better than mine because you're right, that is a gasket. I don't have a carb in my shop or in the scrap pile that has that channel to show...They are few and far inbetween
S
Sbardon
Poolboy, thank you for your patience and insight. As both my Carborater and valve are flat, and I have the sensing... I should use the one on the right. Makes sense to me! Thanks.
It seems both my units had the wrong gasket. Have a variety of old gaskets, not the rights ones though, I will make new gaskets and try them out, and get some proper ones on order.
Thanks again. :smile:
steveg
You might get away with Hylomar instead of a gasket, as it seems to be fuelproof. I've had it on my tank sender gasket for >10 years with no deterioration.
steveg
...you'll have less problems in time to come if you disable the TBV entirely.
Poolboy - how do you disable the bypass valves?
Do you remove them and fit a home-made gasket or blanking plate?
I fitted my recurved BVU distributor and it was idling at 2500 rpm with the idle screws fully off! Both the bypass valve pipes were plugged. When I uncovered the rear one the idle went down to 1200 or so. Adjusting the bypass valves had no effect. Front valve:
poolboy
I make a gasket that covers all the holes except for the 3 threaded holes for the screws that attach the TBV to the body of the carb...then if I leave the TBV guts in place I'll turn the adjustment screw fully counterclockwise. Just using the adjustment screw isn't what I consider permanent and sure as it will depend on the condition and integrity of the TBV diaphragm
I have some substantial gasket material that withstands the force of the vacuum which I use in my rebuilt carbs, but I have seen gaskets made from various metals, from brass to what looks like aluminum or 'tin'.
steveg
....but I have seen gaskets made from various metals, from brass to what looks like aluminum or 'tin'.
Poolboy - thank you for the quick reply!
I've used household aluminum flashing in the past - easy to work; strong enough for blanking.
Edit: installed blanking plates made from alum flashing, sealed with hylomar. No problem setting idle at 1000. FWIW BVU recommends 1000 rpm idle (vs 800) to make cam last longer thru better lubrication.
wangdango TR6 '76 TR 6 stromberg bypass valve? Triumph 1
Paulus Stromberg bypass issues Triumph 4
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
Celtic 77 MGB 77 Stromberg issues MG 12
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 0
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
M General MG stromberg carb MG 5
Sarastro TR4/4A Stromberg linkage question Triumph 4
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
D Stromberg Dash Pot Screws Jaguar 3
Merlin63Tr4 TR4/4A Cracked Zenith-Stromberg float assemblies Triumph 13
steveg Online SU and Stromberg needle database with comparison charting Austin Healey 2
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
R GT6 Carb Floats for Stromberg 150 . Triumph 5
bfitz Zenith Stromberg O ring question Other British Cars 8
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
K TR4/4A Stromberg question. Triumph 13
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
M TR4/4A Stromberg CD175carb query Triumph 7
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
Zimmycobra TR4/4A Zenith Stromberg questions Triumph 13
M TR4/4A Stromberg ? Triumph 4
L zenith-stromberg carbs Lotus 11
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
G Stromberg cd150 question Spridgets 1
TR6BobNF General Tech Midget Stromberg 150 Adjustment MG 8
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
W Weber/stromberg air cleaners Jaguar 3
dklawson Early Stromberg Floats - 150CD Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
W Zenith stromberg carbs Jaguar 3
J stromberg float source or x referance Triumph 2
L Stromberg 175 cd question Other British Cars 5
D TR6 76 TR6 Stromberg Air Valve Triumph 2
H Stromberg Carb Sync and adjust Triumph 6
T Stromberg Triumph 22
sundown 175cd stromberg carbs Triumph 4
JPSmit Stromberg Carb Question Triumph 15
R TR4/4A Tr4a, Stromberg float setting Triumph 6
regularman I found the fix for the stromberg on the 1500 Spridgets 6
A XKE Series II Stromberg Carb Upgrade Jaguar 4
C Stromberg carbs Triumph 8
