BN6 horn button
nevets
The horn button on my BN6 non-adjustable steering wheel is chipped and cracked, and sticks out on one side. I would like to send it out for restoration. How is it removed? Will it require extracting the stator tube? Thanks!
stinky60
Yes Nevets, You will have to remove the stator tube, you will have to remove the Olive nut on the gear box,and disconnect the wires from the turn signal wires. I'm sure others will chime in. Good luck and take your time
steveg
Nevets, the Moss catalog shows it to be similar to the adjustable button. I've had my adjustable-type out. You take a single-edge razor blade and carefully insert it under the edge of the chrome bezel (44) and carefully pry it up. It's a friction fit in the bakelite ring (42).
nevets
nevets
Steve G, so if I understand you correctly, I can simply pry off the horn button with no need to remove the trafficator & stator tube?
British_Recovery
Bronze
If all you want to check out is the horn push, you can do as Steve explains. There will be a spring and a metal disc below. One of the three tabs might be broken, allowing it to pop out on one side. Do not be tempted to remove any screws at this point - you will cause internal problems. For further issues, the whole unit with the stator must come out.
nevets
nevets
Thanks all for the help. On a related note, if I decide to replace the steering wheel with a Derrington style wood steering wheel, could my current horn button be used? I'm thinking not, but wanted to be certain before sending it out to be restored.
steveg
If there's a non-adjustable hub available for the Derrington, the horn button should fit. Make sure you don't get the adjustable hub by mistake.
British_Recovery
Bronze
Go to the Moto-Lita web site. The non-adjustable hub for a wood or leather rim wheel is listed ( B6, I believe ). Others may carry this, and your stator and horn button / control head is used.
Thanks Steve. Yep, it's a Moto-Lita; Mike modifies them for his wheels. Took a while to get the wheel as the hubs were back-ordered, and there's a discrepancy on the depth that barely allows the locking nut good purchase. Here it is in the car:
Your car looks nice with the dash painted body color (as opposed to vinyl matching the interior). I'm surprised it's not done more often, even if it deviates from the holy concours guidelines ;)
I took mine a step further; I can imagine the engine-turned treatment would look stunning against a black background...
gonzo
Personally I would not change a thing. It's well earned patina.
nevets
nevets
Maybe I will retain the 'well earned patina' on the controller, however the horn button is badly chipped. Since the steering wheel is a reproduction, I am also thinking a new Moto Lita wheel would be a very nice addition. And as long as it's all apart, why not get everything spruced up. We shall see. I am a procrastinator, so there is a chance that well earned patina will not be lost.
H horn button for BN6 "non-adjustable" Austin Healey 4
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 BN6 Tonneau Cover Austin Healey 5
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
maxwedge5281 bn6/7 hardtop Austin Healey 18
