galvanized sills for Plus 2 Elan
TomMull
I've just received new sills from Paul Matty. I had originally planned to have new ones made from scratch here in the US but my fabricator got busy making stainless bits for fancy houses and hammer forming new myself ones didn't seem practical. The new ones were on the shelf at Matty's and on my shelf a few days later. (They are the redesigned sills using a tube section rather than a box section as original which negates the need for a large press brake.)
They are plain steel hot galvanized after fabrication. The stainless ones were not available from the usual sources at least.
At any rate my question is, will there be any benefit to painting the galvanized sills? Aesthetics not considered as they will be hidden. I know that galvanized metal is a bit tricky to paint.
All replies appreciated.
Tom
LarryK
You have to sand them pretty good to make paint stick to galvanized. I always had a problem, but sometimes I lucked out and double cleaned and prepped to paint. SS, just polish. I would like to see what someone else does.
TomMull
TomMull
Sound like sanding would be rowing upstream at best and if you sand off the zinc, you might make matters worse.
I think these sills or similar ones were developed by Spydercars to be done in stainless but for what ever reason no one seems to be doing the stainless ones anymore.Thanks for the reply.
Tom
HealeyRick
From what I understand, left unpainted the galvanized layer will eventually wear away, leaving the untreated metal behind to rust. It just is going to take longer. Porsche galvanizes their cars but applies paint over the galvanized metal. This site gives some tips on painting over the galvanized coating: https://www.indmetalstrap.com/paint...=You may or may not,type of paint you choose. Also, be careful welding galvanized, it produces harmful fumes.
LarryK
I don't sand to remove, just to scratch to get primer stuck, then paint.
Platinum
Can't imagine the "audience" to be large enough to justify the expense of fabricating stainless sills, even in England. Galvanized ones should last longer than fuel for internal combustion engines will, IMHO. Coating them with POR-15 may be a good solution though, if another outer barrier is what is desired. Personally, I'd consider the galvanizing to be sufficient.
TomMull
TomMull
Can't imagine the "audience" to be large enough to justify the expense of fabricating stainless sills, even in England. Galvanized ones should last longer than fuel for internal combustion engines will, IMHO. Coating them with POR-15 may be a good solution though, if another outer barrier is what is desired. Personally, I'd consider the galvanizing to be sufficient.[/COLOR]
While I'm not a particular fan of the POR 15, my thought is that it will offer some protection to the zinc coating.
I've recently discovered that SJSportscars in England is still making stainless sills or at least selling them. Of course I didn't have this information when I ordered my galvy ones. The stainless sills are only about 30% more expensive and the shipping quote on their website (which I think might be subject to revision) is less than $40 while I paid $150. https://www.sjsportscars.com/parts-and-accessories/SJ050B0002.htm
Live and learn, but the galvy sills will be sufficient. The car will spend most of it's remaining life in a comfortable garage and galvanized steel road guardrails last from 30 to 100 years exposed to the elements.
Tom
Platinum
Doubt the galvanizing will be in any 'danger' of degrading any time soon. The POR would just add more weight... not really necessary or desirable!
TomMull
TomMull
ACBC would certainly not approve of that.
Tom
Platinum
:iagree: :lol:
TomMull Paint over galvanized parts? Restoration & Tools 8
JPSmit anyone used this? Galvanized coating? Restoration & Tools 1
TR6oldtimer Surprise surprise, it's galvanized Triumph 7
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
J TR2/3/3A Replace rusty sills? Triumph 10
F TR2/3/3A KAS-Kilmartin outer sills with bow to match door Triumph 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR4/4A New Rocker panels [sills] not round enough Triumph 10
F TR4/4A TR4 inner and outer sills Triumph 2
W TR2/3/3A Fabricating inner sills? Triumph 39
T GT6 These sills have been replaced, correct? Triumph 7
R 100 Sills / rocker panels from Lynn Cline, Classis Collectables Austin Healey 3
S TR2/3/3A tr3 inner sills Triumph 21
Xte BJ8 sills aluminium and draught excluder Austin Healey 0
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
oxford kilmartin sills Austin Healey 1
S inner sills, outer sills, a post...where to start? Spridgets 28
W Inner sills Spridgets 0
N Aluminium facing on sills and shut pillar, BJ8 Austin Healey 7
Superwrench inner sills Austin Healey 6
T TR2/3/3A TR3 door sills Triumph 2
Superwrench rockers and inner sills Restoration & Tools 6
John Moore Bugeye - Sills or Floorpans first? Spridgets 6
P TR6 TR6 sills/rocker color Triumph 5
longbridgehealey Got the carpet on the sills!! Austin Healey 4
S Help needed- install inner sills,etc. Austin Healey 9
Popeye Painting insides of sills Triumph 11
John Moore Good news on sills Spridgets 3
A Kilmartin Parts [Sills] Austin Healey 5
J TR6 joining the inner and outer sills on a TR6? Triumph 1
spiny Tips needed on cutting out and replacing sills Spridgets 32
G glued sills? MG 17
J What is the process required to replace sills. Austin Healey 1
R B sills MG 4
J How do I replace sills and rocker panels. Austin Healey 1
P floor pans inner sills rockers,outrigers Austin Healey 10
C MGB-GT Painted Sills on 74 B-GT? MG 6
R Outer Sills [ Rocker Panels ] Austin Healey 1
T Question on Welding sills Spridgets 4
J cleaning out sills Midget/sprite MG 0
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
tr6nitjulius For Sale SOLD! 4/29/22 4 sale ZDDP Plus Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TomMull Dash wiring Plus 2 S Lotus 16
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
TomMull CHASSIS SHIPPING Lotus Elan Plus 2 Lotus 22
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
TomMull Elan Plus 2 post 1968 numbers don't quite match Lotus 0
