TR6 Hood release pictures needed
steveg
My hood release interfering with surrounding interior upholstery panel.
It's hard to use and doesn't seem correct. The carpet board is pretty thick.
Would like pictures of a correct setup. Thank you in advance.
Gliderman8
Mine pretty much looks the same as yours. The release handle moves very little.... I have not had a problem using the release as it is shown. Most of the time I reach under the passenger side and use the emergency release to open the hood (bonnet for you guys east of me :smile:)
steveg
steveg
Elliot,
Thank you for the fast service!
I just last week installed the Moss emergency release rod and it works a treat!
Regular hood release handle placement looks like a cr*ppy design.
Maybe I'll bend the tab to angle the handle outward and do like you and place the upholstery panel over the cable, rather than under it as it is now.
pdplot
Best move you ever did. I never use the factory release cable any more. Stupid design. They should have had it on the passenger side under the glove box like on the Mini my daughter once had.
poolboy
I think they may be on the right hand side on the home market cars....I don't recall seeing these complaints on the TRR Forum
Gliderman8
:iagree:
Dr.T
The hood release handle should be oriented "portrait" instead of "landscape", that way it won't interfere with the kick panel as much.
glemon
What Dr. T said, the emergency release is nice as well. When I first redid my car the regular cable was so tight I could barely open it, and was always worried it might break. After time, use, adjustment and lube it is better now, but unless you have gorilla arms you have to get on the passenger side to do the safety catch, so having the release over there makes sense.
Greg
steveg
steveg
The handle is at this angle because it's built-in. The handle ferrule has a flat side matching a "D"-shaped hole in the welded-on mounting tab which is part of the body structure. The handle itself has an index groove which matches the inside of the ferrule. Hence Elliot's and mine being at the same angle. This could be changed but one would have to bore out the mounting hole to allow the ferrule to be rotated. That would necessitate removal of the cable from the car.
If I do that, I'll make an extension for the mount which would orient the handle landscape as well as moving it inward, further away from the carpet panel.
Gliderman8
You beat me to it Steve.... As you say, there is an indexing flat on the ferrule and a matching flat side on the cable mount in the car.
I guess you could orient it differently but for me, the current orientation does not seem to be a problem.
Dr.T
Is your cable a reproduction part? I suspect is and it is probably the only part available and doesn’t exactly match the original factory part. The picture I posted is of a factory original set up. I’m nervous about continuing to use it and will be installing an emergency release cable ASAP
Gliderman8
Definitely get the emergency release installed.
Gliderman8
steveg
steveg
Dr T - You're right, I'm sure it's a repro installed by the PO. It looks pretty new.
I like Moss' newer rod-style emergency release which looks to be foolproof, rather than the older cable design. They sell both.
I tweaked it a little: rather than drilling the holes for the main screw and stop screw, I tapped them, inserting the screws to the desired depth with locknuts on the back. The Moss-supplied spacer makes the action pretty sloppy, so I bored out a thin SS washer to take up the slack on the excess length of the spacer.
Madflyer
I have heard and seen all the above. My question is why have it at all??? Mine was hard to use and kits and such were new when I restored my car 25 plus years ago. I took it all out cable, lock base, and hood rod all gone, and with a light press on the front of the hood the back opens enough to grab the hood and lift. At 90 plus hood does not lift as some said it might. Most people do not know TR's so could not open it any way. And as stated bad design to start with. Madflyer
Gliderman8
Not so sure it's bad design... it was designed for a right-hand drive car. The cable design works fine if installed on the right side.
steveg
steveg
All they would have had to do is move the flat spot in the mount opening such that the handle was horizontal.
Is it possible that the TR6 is mainly a left-hand drive car with a smaller number made in RHD? Don't have access to the production figures. Something like 3/4 of Healeys were sent to the US.
Popeye
Bronze
I ASSUME, i.e. I really have no clue, but the hood latch may be needed for safety reasons. To pass crash testing, etc. Again, just a swag (scientific wild ... guess) on my part.
Dr.T
I don’t know the exact figures, but I’d say close to 90% of TR6’s were LHD, for the North American market and other LHD European markets such as France and Germany. Who else uses RHD but Britain, Japan and a few Caribbean countries?
R TR6 Stronger hood release? Triumph 4
B TR6 TR6 Hood Release Cable Triumph 7
S TR2/3/3A TR-3 Hood Dzus Will Not Release Triumph 17
RJS Emergency hood/bonnet release Triumph 22
mdionne Hood Release Cable Spridgets 4
jvandyke hood [bonnet] release broken cable Spridgets 34
TonyPanchot TR Hood release HELP Triumph 9
JPSmit Hood [Bonnet] release question Spridgets 1
sparkydave Hood release cable help Spridgets 3
W Hood release Spridgets 3
T Emerg. Hood Release Triumph 12
MadRiver Anyone have hood release cable pics? Triumph 15
S BJ8 Hood Release Mechanism Austin Healey 2
E TR 4 hood release Triumph 3
G TR6 Hood Release on TR6 Triumph 24
T Backup hood release cable? Triumph 14
Brosky New "Emergency" Hood Release Kit arrived today Triumph 3
D Broken hood release cable - problem now solved. Triumph 1
D Help !! Hood release has broken Triumph 11
B TR6 "New" TR6 Hood Release Cable Won't Open Triumph 7
A Hood release mechanism Spridgets 5
KLUTZ MGB-GT MGB GT Hood release? MG 2
B Hood release MG 8
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
