TR6 Binding Clutch Pedal
Gmarshal2005
I’m having trouble with the clutch pedal which seems to feels as though it is binding after driving 15-20 minutes. I bought new master, slave and hose. I’ve bleed the clutch system several times, gotten the air out, then the pedal feels good when engine started, Feels good thru all gears, took for rides, shifts well and then I start to feel the binding! Just can’t figure what it could be !! Any ideas would certainly help, losing great driving days Thanks
Martin Secrest
You bought new master and slave cylinders, or you rebuilt them? What fluid are you using?
When you say 'binding,' do you mean it gets harder to push the clutch through its normal range?
G
Gmarshal2005
Martin, I bought both new and also a repair kit for each. I switched to Dot 4. Had some trouble getting all the air out though!
Berry, I did read your attached article before But, was hoping that wasn’t the problem but, it may be ! Back in August 2018, I had An internal engine problem and the reputable restoration shop had to pull the engine for the fix and it’s noted in his repair report Under transmission that they: replaced the front cover gasket and input seal which required removal of the clutch release fork for clearance. They cleaned the front cover and reinstalled with new hardware including new pin and wire, replaced the front lay shaft cover gasket, separated the throw out bearing from sleeve with press and replaced the throw out bearing And replaced the trans tail shaft seal and also replaced a worn clutch shaft push rod pin and checked the clutch operation Just for some backup. So I guess the only fix is to pull the tranny or have them do it ?
titanic
I admit that every possible culprit should be eliminated before removing the transmission, but I can't think of any problem with the clutch pedal assembly that would cause binding. The bushings in the clutch pedal box are a soft lead like material that would give a lot of "slop" when worn, but not binding. Just a wild guess from here, but it seems like the release bearing sleeve binding on the front cover is the most likely culprit. Whether the previous work done in the area was a factor a matter of speculation.
Berry
G
Gmarshal2005
Well thank you Berry, I’ll have to visit the shop next week to see for one which bearing they installed and why, since I never had any problems shifting in the 11 years I owned my ‘74 TR6 before the engine work was done !
I’ll report what I find out and what I plan to do to get it repaired. Again thanks!
Coleman
George Zeck Binding Calipers ?? Spridgets 8
K TR2/3/3A TR3A New Brake pads binding to New drum? Triumph 4
Moseso TR2/3/3A What could be binding? TR3 Gearbox/OD Triumph 5
Morris Binding wrist pin... Spridgets 12
brgrmyster TR6 TR6 New Suspension Binding Triumph 17
M Midget Window Crank Binding Spridgets 2
NutmegCT Binding choke and piston - it was the front jet! Triumph 2
H Steering Column Binding in 2500M TVR 5
ncbugeye Front wheels won't spin, dsic brakes binding? Spridgets 13
G Wheels binding at lock Triumph 5
B One binding rear brake. Triumph 10
T Binding B brakes MG 5
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
