Under bonnet fuel
barnman
Good evening chaps, just starting to get to the nice bits....discressionary spending!
Bought a 6 branch SS exhaust and looking at the inlet side.
Upgraded the cam from Newman cams...genius old company.. to fast road
Looking at the AH Spares triple weber conversion...is this overkill.....the car will be last nut and bolt rebuild but not a show car. I want it to be fun and a drivers car.
Suggestions/help chaps... always appreciated!!!
Regards Al
If you want to see the car I bought from Denis Collins!!... Fast N Loud season 4 Ep 12..mine is the Blue one
Will post pics at some stage
Regards AL
John Turney
When I had a discussion about what to do with my engine with Denis Welch, I had headers and fast road cam, he recommended 2 HD8s over triple Webers because the useful range of the SUs was better. The Webers are better at full throttle, of course. I drive fast, but only go full throttle when I have the room, which is not often enough.
Here in the Colonies, with mile upon mile of open, often straight road, highways and freeways the 3.4:1 rearend has longer legs (assuming you have stock 3.9). 'Off-the-line' acceleration suffers a little--Big Healeys aren't generally good drag racers anyway--but the lower noise and vibration at highway speeds is welcome, and first and second gears are more usable (IMO). The uprated OD accumulator from DWM offers a little quicker OD engagement, and I just learned AH Spares has an accumulator with an O-ring instead of iron rings, which should last longer (although I just replaced my accumulator at 205K miles and, although there was some scoring, it was good enough that I 'donated' it to a needy owner). Well-trued and balanced wheels and tires will help minimize the dreaded 'scuttle shake.'
DerekJ
Twin HD8s work great with a fast road cam. I had that set up on my car then upgraded to the the DWR Rally cam and Triple Weber’s. The HD8 provide more than enough fuelling for the fast road set up. The Webers provide an instant throttle response due to the accelerator pump but are overkill for a road car with a fast road cam. They do look good though.
steveg
From SU CARBURETTERS TUNING TIPS & TECHNIQUES:
Jonstock
Recently had the engine in my BJ7 rebuilt. Gas flowed head, fast road Kent cam, steel flywheel, Omega pistons, 2 x HD8 carbs, bespoke 6 branch exhaust manifold from Zero, big bore s/s exhaust. Set up on rolling road achieved 172bhp at flywheel. Goes really well, and makes a terrific noise. I have pertronix ignition. I also had the radiator re-cored, and temperature stays at 190C even in the current heatwave
Just curious, what is considered a heat wave in England? We've averaged 95-100degF here in the Central Valley of California for the last couple months (and we've hit 105 more than a few times).
Editor_Reid
Platinum
My theory has long been that anytime the mercury hit 55F, BMC did their hot-weather testing. You know, to really put a strain on the cooling system - take it to the limit, exceed any expected actual use!
Dandare
I went to school in the UK in the sixties and when it reached 84℉ we were allowed to take our blazers off and, if you were daring, loosen the tie a smidge!
Danny
Rob Glasgow
Bob, I spent most of my life about 20 miles south of you and I can attest that nothing quite feels like driving a Healey with the top down at 5 PM in 105 degrees. You've got furnace blast heat coming at you from all angles.
Worst for me was driving through Death Valley in the early summer near (aptly-named) Furnance Creek. Temp was 115degF in the shade and, in addition to the mirages I was hallucinating; my navigator kept misting me to keep me from passing out. Pulling the long grade up the Panamint Mountains the gauge read a steady 212, and that's with the heater on full blast. Still, we made it, and there was a bus and several cars on the side of the road with their bonnets up.
W Electrics, fuel system, under bonnet temp. Austin Healey 3
C Under boot and under bonnet paint? Austin Healey 7
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
I TR6 Under bonnet sticker source Triumph 3
Jim_Newman From under the bonnet there arose such a clatter. Austin Healey 1
MCNX_BFF Under bonnet ugliness-advice, please Triumph 13
T Forgot to check under the bonnet... Triumph 16
drooartz Engine is under the bonnet! Spridgets 7
NutmegCT Under bonnet cleanup Triumph 27
SHG Brake Fluid Splashing Under the Bonnet Austin Healey 62
M 74 xke under bonnet black colors Jaguar 11
NutmegCT under bonnet prep MG 3
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
J TR2/3/3A Pads under new floor Triumph 7
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
D MGB Stopping rust under patch panels MG 1
T Coroplast Signs under Wheels Austin Healey 0
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D TR2/3/3A Under hood Photos Triumph 7
D Lilly under her own power... Austin Healey 7
G TR4/4A Under Dash Pics Triumph 2
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
K TR3A Air vent under grille on Race Cars? Racing 5
D TR4/4A shims under axle housing Triumph 7
simon1966 BN1 Strip down well under way Austin Healey 5
M TR2/3/3A The Sequel: Water from Under the Dash Triumph 3
Simmo MGA Missing under load MG 3
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
Joe Reed MGB Rattle under front end? MG 8
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
AUSMHLY BJ8 eyebrow over or under grill surround Austin Healey 9
