TR2/3/3A Front Suspension
Skidude
My 59 TR3A has a bad case of understeer. The car has Spax adjustable shocks - were on the car when acquired. Don't know if it's the steering box, shocks, tires (tires have great tread - but are older), alignment or what. Any ideas where to start?
CJD
In stock form these cars naturally understeer a bit, but can be accelerated into oversteer pretty easily. Your only adjustment is toe. Excessive toe in can cause understeer, so you should check that first. Camber would be next, but there are no adjustments for camber. If it is off, you have a bent component.
Of course, tires are where the rubber hits the pavement. You could have old tires up front that have hardened and lost their grip...
S
Skidude
There's a really good tire shop for sports cars in Cincinnati (owned and operated by a former racer and race mechanic) - I'll start out with new tires and alignment and see where that takes me. I have wire wheels - is there anything special I need to know prior to buying the new tires?
pdplot
Your tire pressures are fine. I had two Corvairs that required about 10 lbs. higher pressure in the rear tires to cut down on oversteer. Many owners forgot and paid the price.
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
F TR2/3/3A front suspension Triumph 3
