Steering box lube
Michael Oritt
I cannot locate a domestic source for the Penrite steering box lube. Unless someone knows of a place where it is available what other products are recommended? I know lots of people think highly of Corn Head grease, especially for leaky boxes, and I think either it or an equivalent is available at Tractor Supply. Does anyone have thoughts on Amsoil's Extreme Pressure Gear Lube which I use in the dogbox of my G4 and is pretty tough stuff?
John Turney
Penrite Steering Box Grease is a NGLI grade 00 grease. NGLI grades are like SAE oil grades for viscosity, except for greases. Normal chassis grease is NGLI grade 2. Corn head grease is NGLI grade 0. The higher the number the more viscous, all the way to grade 7, which is a hard wax. Amazon has some NGLI 00: https://www.amazon.com/s?k=nlgi+00+...410855&tag=googhydr-20&ref=pd_sl_413okb9lbb_e I've seen the Champion before, but I'm still working on my bottle of Penrite.
Deleted member 21878
i use the cornhead grease. never had a leak. got mine at a local John Deere tractor place.
i put mine in while i had the box out and the top off. just packed, rotated column, and packed and packed in some more. easy with it out. not so sure with the box in. Maybe if you got it heated, it might pour.
Michael Oritt
Michael Oritt
Thanks Lin--I'll work the time difference and order now!
twas_brillig
twas_brillig
John - thanks for the explanation regards grades of grease. Doug
RDKeysor
Bronze
My BN7 dumped its steering box contents without any warning. After reading up on the alternatives, I bought a standard grease gun tube of John Deere corn head grease, $5 or $6. I filled the steering box by simply removing the tip of my grease gun and pumping it full. I was told it is best to swing the wheels from side to side during the fill process to ensure the box is full. I did that. One tube was more than enough, and I have seen only the very smallest amount of leakage after four or five years, that possibly being the remnant of the original oil that went missing.
vette
I still have some Penrite left and I use a large cooking syringe to fill my steering Box. Even though the Penrite is the right viscosity I still get some leakage thru out the summer driving season. So I refill my steering box every spring. Try Healey Surgeons or Abingdon Spares for an alternate source.
BoyRacer
Trying to fill the steering box though the filler hole will take forever. Remove the top cover and use a tablespoon to ladle in the grease. Moss now sells a European product instead of Penrite. Don't recall the name. I have used it on one of my Healeys and my Alfa. Works great and no more leaks. You will be surpised at how much it takes to fill that box. Do it in warm weather. It takes forever to flow down into the bottom of the box when it's cold.
steveg
I'm currently using this. Same viscosity as Penrite and the Moss product. Since I had the cover off my box so many times a couple of years ago, I did like Richard and filled it with the top off.
I heat it up in a bucket of hot water first.
PS - think the Corn Head grease is good too, but harder to remove as it probably won't drain.
DWR sends a quart of Miller's steering box lube with their uprated steering box. Just FWIW, I haven't installed the box yet (hope it doesn't leak, as this stuff isn't easy to find in the 'States).
Michael Oritt
Michael Oritt
I am about to reinstall the trafficator that Curt Arndt rebuilt for me (Beautiful job) and need to decide upon which lube i will use.
Between this forum and other sources it appears that many owners use several different products, and the decision to use those with higher viscosity, such as Corn Head grease or the like seems to be driven by whether or not one's steering box is leaky. I don't know which product was in my steering box but when I drained it what came out seemed relatively liquid and in any case I have in the past not experienced any leaks.
I am inclined to use an EP product such as Amsoil's Severe Gear 75-90. Does anyone feel this would be a mistake?
... I am inclined to use an EP product such as Amsoil's Severe Gear 75-90. Does anyone feel this would be a mistake?
Nope. Theoretically, EP oils could 'attack' the bronze bushings, but this is such a relatively low-stressed application it would probably take decades to cause any problem.
John Turney
Yes. It's viscosity is too low and not made for high speed gears and not the low speed steering gears. If you didn't experience any leakage, use a grade 00 grease. Gear oil has a viscosity similar to grade 000 grease.
Michael Oritt
Michael Oritt
Thanks Joh. For whatever reason the local Tractor Supply does not carry an appropriate product but I got a tube of Amsoil's equivalent from the local rep.
Someone made the comment that it is easier to remove the steering box lid and spoon in the product versus trying to get it in through the hole. This makes sense to me and I think I'll give that a try unless someone feels I am inviting trouble by doing it that way.
BT7 Owner
Michael,
I rebuilt the steering box on my 62 BT7 and used Corn Head grease form the local John Deere dealer. You should be able to get a needle type grease fitting part for your grease gun and pump it in through the top as others have said.
The Corn Head is designed for slow moving worm drive units. It will stick to the worm gear and will not wipe off during its rotation. I had the top of mine off to see how it adheres, it really does. It is just a rotating ball of grease.
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
RJS Correct Lube for Steering Box/Rack? Triumph 1
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A The steering box again? Triumph 9
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
B Outer steering column connection to the steering box Austin Healey 6
simon1966 Steering box lubricant Austin Healey 17
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
K TR2/3/3A Steering Box Triumph 2
M BJ8 Steering box removal Austin Healey 8
T Steering Box Pinion Seal [?] Spridgets 1
