Routing of Hand Brake Cable
Sal36
Group,
I have been unable to find any description of how the Hand Brake Cable is routed from the pull handle to the balance leaver on my 1961 AH BT7 or any other model of the big healey. I don't think there would be much if any difference between big healey models. Can someone either post some pictures or give a detailed description of how the hand brake cable is routed.
Sal
red57
Hi Sal,
I can partially help - here are pictures of the forward portion of the cable mountings/routing. This BTW is a '60 BT7 and I think you are correct in thinking they are all the same.
The front cable attachment is pretty self explanatory and then it slopes downward to run under the corner of the floor and, as you can see, I put a wrap of hose with a tie-wrap where it passes under the corner of the floor to keep it from rattling and then it loops up over where the stock shock mounts and is held by a clip with a bolt thru to a weld nut on the bulkhead panel. From there it goes rearward and down to the cable mounting on the rear axle. So the only actual mountings are the front cable end mount, the bulkhead clip, and the rear cable end mount.
I didn't take pics of the attachment to the rear axle on my car because I have bespoke tube shock mounts that required the cable to be moved inboard and the bellcrank to turn the opposite direction so I figured it would just cause confusion.
Hope this helps.
Dave
red57
Sal,
It's a proportioning valve. I have rear disc brakes and when you make that change you typically need to dial back the rear brake action a bit to keep a front brake bias for safe stopping. After it gets initially set, there is normally no need to fiddle with it. By putting it there, I can reach it while driving the car with the rear seat removed to get it where I want it, and then put the seat back in and it's out of the way and can't get accidentally moved.
Dave
Deleted member 21878
another view. there is a p-clip above the shock. i used the same hole and bolt for the p-clip that holds the battery cable. one up and one down.
M Right Hand Drive cable routing Spridgets 11
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R TR2/3/3A Speedometer Routing Triumph 15
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR4/4A What is the routing for the speedo cable Triumph 2
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
AHS TR2/3/3A Disc brake line routing Triumph 0
M TR2/3/3A OD wire routing question Triumph 14
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
M BT7 Speedo Cable Routing Austin Healey 3
C Vacuum line routing for brake booster Austin Healey 5
D Fuel Line Routing Spridgets 9
J Sprite Bonnet release cable routing Spridgets 2
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
