TR2/3/3A scuttle vent
cityslicks
What's the secret to re installing the scuttle vent lid???seems like the cable is too long and re attaching the cable to the vent screw lid is difficult to say the least I must be doing something wrong .
sp53
It depends on the center pivot rivet; if that has a snap ring then hook up linkage as 2 pieces at both ends then put the rivet and snap ring on last as you bring those 2 together. The barrel that the cable goes through needs some free play so the whole assembly can fold in on itself. The large spring with 2 ears can go on later also.
steve
DavidApp
It is challenging to get installed.
Mine had a rod rather than a cable.
David
The mechanism. Home made as the original was missing. I bought a rusty one on e bay and copied it.
Installed.
Graham H
It is a tricky little beast, it was the first thing I fitted after my rebuild because there was nothing in the engine bay and I could stand right up close, good luck.
Graham
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
PatGalvin Scuttle Vent Rubber placement Triumph 4
M Sebring Scuttle Vent Austin Healey 3
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
S TR6 76 TR6 Scuttle Vent Triumph 16
G Scuttle Vent Adjustment Triumph 1
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
71tr Scuttle Vent Removal Triumph 7
P TR2/3/3A TR-3a scuttle vent assembly question Triumph 2
B TR2/3/3A TR-3 SCUTTLE VENT ROD INSTALLATION? Triumph 14
T TR4/4A 4A Scuttle Vent Seal-Gasket Triumph 6
NutmegCT TR2/3/3A scuttle vent actuator rod - TR3A Triumph 3
R TR6 TR6 scuttle vent style Triumph 10
G Scuttle vent conversion Triumph 1
harmsc Scuttle Vent Triumph 6
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
L TR2/3/3A Scuttle / front fender attachment Triumph 9
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
